(Topic ID: 251384)
Black Knight: Lower Eject Hole (Multiball) weak?
By kevinclark
#1 4 years ago
I’ve nearly got my black knight playable! The flippers are now working ok (not great, but I’ve got rebuild kits coming). Unfortunately when I shoot the multiball lock on the lower play field any ejection goes directly down the trough. There’s no way for a flipper to catch it.
The arm that hits the ball looked like it might be slight askew so I moved it closer to the center of the trap hole, but there’s no change.
Thoughts?
#2 4 years ago
Bend the arm to aim the ball where you want.
#3 4 years ago
I’ve moved the arms to both sides of the gap available and see no change. I’m not sure positioning matters at all in this case - the ball pops out but hardly hits the barrier and rolls straight down rather than ricocheting.
#4 4 years ago
I would bend this metal ball guide to the left so it directs the ball more toward the left flipper. Probably gonna take some trial and error, but that should hopefully do it.
#5 4 years ago
Yes it is definitely moving along the right railing, just need to tweak it out a bit, and of course assuming the game is perfectly level already.
#6 4 years ago
I would pull the mech apart, clean the old grease off the pivot point. Lightly lube with some silicone grease. New coil sleeve. Inspect the coil stop and plunger for mushrooming. Replace as needed. If it still shoots SDTM, then bend the ball guide.
#7 4 years ago
You could also try bending the rail to the right, so that the ball bounces off that rubber post..
1 month later
#8 4 years ago
Turned out the machine just wasn’t level. Playing much better now, thanks!
$ 1,059.00
Westjordan, UT
$ 69.00
Pinball Pimp
Metal-Mods
Newcastle, OK
$ 649.95
Pin Stadium Pinball Mods
$ 59.95
Hookedonpinball.com
Hookedonpinball.com
$ 95.00
Pinball Mod Co.
Tools
Pincoder Store
Playfield - Plastics
The Pinball Scientist
$ 8.00
Tools
Nezzy's Pinball Prints
$ 53.95
2,500 (OBO)
Vista, CA
$ 959.00
$ 160.00
Sparky Pinball
$ 17.00
Metal-Mods
$ 18.95
$ 69.00
Pinball Pimp
This page was printed from https://pinside.com/pinball/forum/topic/black-knight-lower-eject-hole-multiball-weak and we tried optimising it for printing. Some page elements may have been deliberately hidden.
