I'm helping a buddy of mine get his Black Knight LE fixed up, and the left side flippers stopped working. Right side flippers work fine, though. I did nearly everything I could think of to get the flippers working...here's what I've tried so far:
-New cab switch (for upper and lower left flippers)
-New header pins on 2J10 and new female connector w/ trifurcon connector pins
-New coil diodes for upper and lower flipper coils (triple-checked diode orientation to make sure I didn't mess it up, the diodes that were originally on the coils checked good w/ my meter but replaced them anyway)
-Cleaned/filed contacts on flipper relay on driver board
-Cleaned/adjusted EOS switches for both flippers
-Checked flipper coils (out of circuit) and got approximately the same readings on both: middle lug to non-banded side of diode lug: 23.5 ohms, middle lug to banded side of diode lug: 1.0 ohm, banded lug to non-banded lug: 24.5 ohms. I believe that means the flipper coils are ok.
Now here's what gets me: there is approximately 32 VDC at each of the left side coils, on all 3 lugs. The voltage to the right side coils (which again, are working) may be a volt higher, but it's very close to the voltage I'm getting on the left ones. I tried grounding the right side upper flipper coil very quickly using an alligator clip on the non-banded side of the flipper coil diode (the ground side) and it fired (I had touched the other end of the alligator clip to one of the cabinet side rails). Tried the same thing on the upper left flipper coil--nothing. It appears that the voltage is there, but even grounding the coil directly isn't firing it! I think I may need to try this test again, it just doesn't make sense to me that it wouldn't fire that way.
I feel that I've exhausted nearly every possibility, so I was hoping to find some help here. I'm at the point now that I think I need to double-check all my work from yesterday to make sure I didn't mess up something else while trying to fix the problem. I did check any board work I did with the 2J10 connector and flipper relay to make sure I had continuity for each trace from each solder joint to wherever it went to. After all the work we did on the game, the right flippers continue to work fine, and we still had about 32 VDC at each of the non-working flipper coils.
Like I said, I'm going to double-check all the work I did so far to make sure I didn't mess something up while servicing the game. Also, I presume the LE version of this game should not behave any differently than a non-LE version but figured I'd specify that it is an LE in case that makes any difference.
Any suggestions where to start looking next?
Thanks for any and all help!
Trevor
