I am restoring a BK and did a playfield swap. Everything is functional and working except for two switches not registering - and I don't know where else to look.
I cannot get switch 13 (spinner) and switch 21 (Left Kicker - but listed as "Lower Kicker 3-Bank Left Target") to register when doing a switch test and physically having the contacts touch. I have checked the diodes on both switches and the ones on row 5 of the switch matrix - all good. Looked for loose and broken connections - none, all good. Swapped #13 and #21 with known good switches - still won't register. I can get every switch to register on the switch matrix except 13 and 21.
I am not very knowledgeable with chipsets and the main boards, but could this be a board/chip issue if everything on the playfield seems solid?
At wit's end and can definitely use some advice/direction. Thanks!
