So it seems the past owner of my BK used whatever fuses he had laying around his shop. They are almost all 32 volt (with the exception of some original 250v) and the amps are all over the map. One was about a 1/4 inch too short and was just resting in the holder. Hopefully this was the cause of my problems (past board damage on start-up). Everything else checked out good, (except for not having a ground plug on the the plug in).
I'm going to order some fuses today, does this list look right?
1/4a-slo blo
2.5a-sb
8a
15a-sb
4a-sb
20a
Is pinball resource the best place to order fuses? After these are replaced should I cross my fingers and boot it up?
