(Topic ID: 154399)
Black Knight Drop Target Lower Arrow Light Stays On
By Toddman
  • 10 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by Toddman
#1 3 years ago
In the upper play field the left bank of drop targets lower arrow is on when you start a new game, not fully bright but on. Ones you knock all 3 targets down on the upper play field the left bank the lower arrow lights bright.
I have replaced IC19, Q47,Q46 and S1 still have the same issue.
Lamp test it turns off and on like it should, during attraction move it flickers on and off almost like it has a 3 positions Off, On, On correct brightness, delays fully off.
What might be causing this?
#2 3 years ago
That's an LED, yes? Put incandescents back in there and see if it goes away.
#3 3 years ago
Yes it is an LED, it does not do it with an incandescent.
#4 3 years ago
Try rotating the LED in the socket 180 degrees
#5 3 years ago
No difference, tried a different LED same thing
#6 3 years ago
Any idea?
#7 3 years ago
I'm tapped. I have never used LEDs in a pin.
#8 3 years ago
what causes this?
#9 3 years ago
Maybe there is a short between a row in the light matrix causing it to turn on with another?
speculation as I see row two of the light matrix contains the ball in play light which is practically always on, shared with the top left center arrow.
#10 3 years ago
Thanks for the input, i was able to track down the problem today. What i found was a bad Diode on the "#2" Bonus light, the Diode checked fine with my volt meter but seamed to leak low power back into the Red/Brown wire causing the drop target arrow LED to be dimly lit. Not enough power to light an incandescent bulb.
So this is how I tacked it down, I checked all the diodes but to now avail. I decided to un-solder the two Red/Brown wires from the arrow that was lit but shouldn't be. I then powered up the machine and started a game, when i touched one of the two wires back to the terminal I removed them from the light came back on, when i touched the other Red/Brown wire nothing happened, so I knocked down the 3 targets and the light came on like it should. With one of the Red/Brown wire still off i switched the game off and back on to put it into attraction mode and looked to see what other lights were off with this one wire disconnected, the "#2" Bonus light was not on, so i reconnected the Red/Brown wire to the arrow and unconnected them from the "#2" Bonus light. I then powered up the machine and started a game again the drop target light was no longer lit until i touched one of the Red/Brown wire to the #2 Bonus terminal then the drop target arrow light came back on and it shouldn't have unless power was back feeding, decided to change the Diode hooked the wires back up and all was good. This also corrected some other issues i was having with LED's, all is good now.
$ 75.95
$ 79.95
Lakewood, CA
