This pin is killing me. I have made mistakes and the pin seems to have gremlins as well.
Pin was working great and then the GI decide to go out. I am using a new Rottendog power supply. I have checked continuity from the GI connector pins through the cabinet, backboard, playfield, and cabinet door. Everything is okay. No voltage readings to cabinet, backboard, playfield when the pin is turned on and the GI is connected to the power board. The 6.3vdc connector was brown so repinned that. However, I am not reading any voltage on the yellow 6.3vdc wires coming from the cabinet. All other voltage test points on the Rottendog board check out okay - no 6.3vdc test point on the board.
Thanks to everyone that continues to help along the way.
