(Topic ID: 301448)
Black knight boot issue
By martymart
2 years ago
  • 18 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by martymart
#1 2 years ago
I am working on a Williams 1980 Black Knight for a friend and when I boot the machine up I am getting an error.
The display is showing 2500 4 and I cannot start a game but the flippers are working.
Is anyone able to assist me with what this code means and where I need to look first to get this machine going
#2 2 years ago
Have batteries or NVRAM installed? This is what happens when the batteries die and it loses the memory or after installing NVRAM.
Try opening the coin door then turn the game OFF/ON very fast.
#3 2 years ago
Quoted from PinballManiac40:
I just tried that and it didnt work.
I also depressed "Advance"switch and now the displays have also stopped working completely once I turned the macihine back on.
I am not sure what I have done here.
-1
#4 2 years ago
May take multiple OFF/ON tries to get it to boot in attract mode.
-1
#5 2 years ago
Quoted from martymart:
Sounds like the game did not boot on that sequence. Try again.
#6 2 years ago
i read that you have tried it, but i had exactly the same issues happen, until i did the on/off quickly twice, then it was fine.
have you tested the white interlock button to the left of the cabinet just inside the door?
#7 2 years ago
Ok. Thanks for everyone’s help. I have tried that and it now looks like I have the attract mode going.
I am not able to start a game though and still I don’t have any displays working. Where do I need to head next.
73BFCB6C-58DD-4F8B-A059-430AFA83C424 (resized).jpeg73BFCB6C-58DD-4F8B-A059-430AFA83C424 (resized).jpeg
#8 2 years ago
Check the fuse for the displays on the power supply board. (Fuse F1, 0.25A slow blow)
Also try adding credits (insert quarters) and see if that will allow you to start a game.
#9 2 years ago
Also, make sure you have 3 balls in the trough, as the game will not allow to start without them detected. The trough switches may even need to be adjusted.
#10 2 years ago
For maximum annoyance, black knight will also not start if it sees MORE than 3 balls in locations. The locations balls can be in idle: 3 trough locations. Shooter lane. 2 bottom lock troughs. So a stuck switch in any of these can be an issue. (The lock trough switches seem to get mangled a lot)
Get the displays working first though. You know they work because you had them working once and the fuse probably blew with all the flicking on and off trying to get the game to boot. Once they're working you can get into switch test and see what switches need attention.
#11 2 years ago
Thanks everyone. I have ordered some new fuses so I can get the display running again.
Once I am at that point I will check all the other items everyone has mentioned.
I will provide an update then.
#12 2 years ago
I have had another look at this today and I have now had the machine go back to not booting.
Is this a common issue or is there something else I need to look at. I didn’t try flicking it on and off again as I wanted to check if something else needs doing to hold the attract mode.
I had also pushed on the display fuse (without any power) earlier and the display is now working again. Think I have a cold solder joint there so will sort that later. The display is showing the same error code as before.
As a next step what do I need to check if it isn’t holding the attract mode or do I just get it back in to attract mode and go from there.
Thank you to everyone for your advice.
#13 2 years ago
entering audit mode with 2500 4 or 2500 3 (4/3 is the revision # of software, 500 is the game number, and 2 means blue system roms) is a good thing. That means the board is booting and running.
Your 5101 ram is likely bad/marginal which is why it keeps entering audit mode at bootup.
#14 2 years ago
Quoted from slochar:
That is great news and thank you for the feedback. I will look in to the ram next and will see how I go.
#15 2 years ago
Does your board have the AA batteries installed properly? Are the contacts on the battery holder clean and not corroded? Check that battery voltage is making it to the 5101 by measuring between ground and pin 22 on the 5101
#16 2 years ago
I have just checked the voltage at pin 22 and I have 4.6v which looks to be ok. I have reseated the batteries and have managed to get the game back in to attract mode and I can start a game (ball was not in the trough correctly so that has sorted the game start). I have a blown fuse on the solenoids and I am out of that type of fuse so will order some and go from there.
I will check again later to see if it holds next time I turn it on.
Thanks for everyone’s help so far.
#17 2 years ago
Fuses can be found at electronic stores, auto parts stores and home improvement stores.
#18 2 years ago
Thanks everyone for your help. After reseating the batteries and the ram chip (is socketed) I can get the game to consistently boot.
Now I have an issue where once I start a game the solenoid fuse blows so I will need to work through this to identify the root cause.
$ 1,059.00
Flipper parts
This page was printed from https://pinside.com/pinball/forum/topic/black-knight-boot-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
