So I've been reading and reading, trying to diagnose and fix this problem on my own but I just can't get to the bottom of it.
When I turn on my BK2K, everything is fine for about 10-15 minutes. But then, the GI on the upper playfield will suddenly start to dim. This starts with the pop bumpers and the upper left GI and eventually (maybe 10-15 minutes later) includes the right side GI and top WIN lanes. The GI on the WAR lanes is not affected as far as I can tell.
I checked all the fuses, especially the ones on my interconnect board. I checked the connectors, on the backbox interconnect board and the interconnect board for the upper PF under the PF. There is a previous burn, which I think was fixed, on J710-9. See pictures below. This was there when I got the machine though.
The issue started after I wired in an extra spotlight for the left side of the upper playfield. It was fine for about a week and then this issue started. Since then, I removed the extra spot and re-soldered the connection at the socket I was using. The issue persisted even when the socket was disconnected. Should I try to clean it up more and re-solder again? See below.
When it works, the voltage is around 6.1v and when it drops, it goes down to about 2.8-3.5v.
This is my second pin and I definitely have a lot left to learn. I'll also say that the playfield and GI are all LED'd. Thank you in advance for any and all of your help!IMG_2340 (resized).JPG IMG_2343 (resized).JPGIMG_2344 (resized).JPGIMG_2349 (resized).JPG
