My Black Knight 2000 machine plays well except for two annoying issues.
1. When I get "the kings ransom", the machine immediately feeds two balls to the plunger lane. The behaviour should be that it feeds ONE ball, and let the player plunge that ball. When the ball is plunged, it should feed the third ball. The problem now is that I get two balls in the lane which makes it very difficult to plunge the balls to the upper PF. It usually ends with having to remove the glass and take the balls out manually...
I've done the switch edges test. The outhole switch, 3 ball-through switches and the plunger lane switch all works ok.
2. I can only do lane change to the right. The switch edge test shows no switch issues. When I press left and right flipper button during switch edge test the display shows "lane change left" and "lane change right"...
Any Ideas? The fact that in both cases the switch edge test shows no issues makes me wonder if the problems are caused by the same thing.
