New machine several weeks back. Was getting 3.2v or so on backpanel GI bulbs. Removed interconnect board and found it to be burnt up in places with solder traces and jumper wires..as expected from the pics and feedback from the forum. Attached the old photos..and also the new
Repinned J7 - did both the pins on the interconnect board and new connector with molex .156 trifurcon crimps. I haven't touched the incoming feed which plugs onto J6 ( vertical on side of board ) as that has black jumper wires a plenty linking to burned off tracks and I didn't want to play with too much first time soldering.
After re-installing i now see 4.2v at the backpanel GI bulbs which is an improvement but not quite what it should be.
Checked directly at transformer outputs and on Yellow / Yellow White wires I'm getting 5.6v AC when it should be 5.9v - not sure if that is major ?
At the other end of those wires on the IDC plug I get 5.3v so some voltage drop...
At J7 ( GI lights ) across pins 10 & 8 and 9 & 7 i also get 5.3v so the jumper wires from J6 are working.
However when i plug the new connector back in and check the voltage on the backboard wires I am seeing 4.2v across each bulb.
The lights all work but still look a bit dim in a lit room.
What should i be looking for that is causing the voltage drop between the interconnect board and the GI bulbs. Could it be resistance in the bulbs or the old bulb holders ? Anything to check next thanks.
Cheers
Ged
