I COMMENCED IMPROVING THE OPERATION OF THE MACHINE AND HAVE CREATED SEVERAL TECH ISSUES:
1. THE OUTHOLE SOLENOID FIRES WHEN THE GAME IS TURNED ON AND WILL CONTINUE UNTIL PUT ON DIAGNOSTICS.
2. THE SWITCH IS OPEN AND THE DIODE HAS BEEN TESTED IN SWITCH & SOLENOID
3. IN THE SOLENOID TEST ALL WORK FINE.
4. IN THE SWITCH TEST ALL SWITCHES IN THE COLUMN (4) ARE SHOWN AS BEING ISSUES.(OUTHOLE -POP BUMPER -ETC)
5. WIRING HAS BEEN CHECKED ON ALL SWITCHES IN THE COLUMN - NO ISSUE FOUND
6. THE GI LAMPS DO NOT COME ON-THE CONNECTION 3J9 IS LIKE NEW AND TESTS THE CORRECT VOLTAGE
7. 3J8 GI OUT IS FINE.
CAN SOMEONE INFORM ME WHETHER THE PULSING SOLENOID APPEARS TO BE A SHORT OR SOME OTHER POSSIBEL ISSUE.
THE GI LAMPS WERE ALL WORKING UNTIL I GOT THE GREAT IDEA TO REPLACE 44 LAMPS WITH 47s.
ANY IDEARS WOULD BE GREATLY APPRECIATED- AS A COMMENT THIS IS A CALIFORNIA PIN WHICH HAS HAD LITTLE PLAYING TIME
AND THE BOARDS + WIRING ARE ALL LIKE NEW IN APPEARANCE & OPERATION PRIOR TO MY INTERVENTION.. I HAVE NEVER FACED
ANY OF THESE ISSUES PREVIOUSLY.
