Been trying to fix this for longer than I can remember, and recently decided to give it another go. My BK sound is working, but it's playing the incorrect sounds and speech calls. It's been an intermittent problem, doesn't always do it. When it does, though, the incorrect sounds/speech calls are always the same ones. I've crimped new female connector pins, and re-flowed solder to male pins on sound board. I tried a sound board from my buddy's BK and it worked fine, which leads me to believe the MPU and wiring is good. I just replaced the PIA today, but the problem remains--in fact it will only play the incorrect sounds since installing it (for as long as I've tested it). I did try re-seating the ROM and CPU chips at some point, and the problem went away for a couple hours. Turned the game off, then later turned it on and it was back to making the wrong sounds. I did have the board professionally serviced years ago, and it worked fine until the past couple years. There are new caps and the 4 bigger chips on the board all got sockets. not sure what else was done on it, though. I don't believe the ROM chip has ever been replaced, and I'm wondering if that should be my next move. Another sound-related issue that may be another symptom: The background sounds (hard to describe them, but it's like DUN-Dun-dun DUN-Dun-dun) start playing shortly after the game is turned on, and it continues right through diagnostic tests until I do the sound test. As soon as I advance from the sound test, the background sounds start up again. It never used to do that, and I figure whatever is causing the problem may also be responsible for that. So, any ideas what to check?
Trevor
