First post. Recently bought a Black Knight machine off of FB marketplace here in Virginia from a single machine owner. Was listed as non-working due to blowing the solenoid fuse. With further troubleshooting I am finding the MPU to be an issue as it usually locks at "0". Hoping someone can help me step thru this a bit. Have not done any soldering to printed boards with chips etc. but have soldered other things and generally know how it works. I have no supplies on hand of component parts. Just a meter, schematics, very basic soldering gear, a new fuse set for BK from Marco. I have the PDFs of the schematics but I am not a guru on using them for tracing down circuit paths.
Current state:
Driver board removed, MPU with 1J2 cable connected only. IJ2 cable while connected to board read proper voltages per schematic.
Observations:
Normally goes to 0 on the display and stays but sometime will randomly boot with a "t" or another number from the trouble code list. Nothing regular or consistent but stays on 0 90% of the time.
Voltage tested at the 1J2 cable and shows normal per schematic.
Voltage tested at the Test Points:
Expected reading per schematic - see attached image.
1 - 12.5v
2 - 1.1v
3 - 118mv
4 - 13.5mv
5 - 4.86v
6 - 2.46v
7 - 4.59v
8 - 4.95v
9 - 5v
10 - good continuity with ground
Previous owner first started having the solenoid fuse issue late last year. He send main and driver boards to a guy that repaired boards. Got boards back with some new chips and stated that boards worked when final tested after work. Previous owner reinstalled into machine and it still would blow fuse and also would not boot as it is now. I got the machine end of March. May reach out to tech that did the work unless I get some promising leads here. thanks.
Pics below are before anything was disconnected obviously.
IMG_0994 (resized).jpgIMG_0995 (resized).jpgIMG_0996 (resized).jpgIMG_0997 (resized).jpg
