First of all, I am new to pinball machines entirely and just helping out some family. But I do have some understanding of electronics in general.
Symptoms:
System turns on but displays 04 00 code in bottom left display.
Can get into attract mode by holding down the right-most button on the inside swing out door several times.
Can add credits by bumping the switch contacts on one of the coin slots.
At this point I cannot get the game to start though. I am just pressing the button on the left side of the front panel. Is that correct?
Attempted fixes:
I did try to re-seat the 40 pin connector, no change.
The batteries in the unit had failed and corroded. I removed the batteries and cleaned the contacts. No acid had gotten on the main board. Batteries then replaced (positive side of each battery aimed to right hand side as per board marking). Did not change the 04 00 code though.
Once it is in attract mode the lighting and sound both seem functional.
Any suggestions on what I should be looking at?
Thank you
