(Topic ID: 192090)
Black Hole... Wont start
By itsab67
1 year ago
  • 27 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by itsab67
#1 1 year ago
I just aquired a Gottlieb Black Hole pinball. When powered on, i get the famous Gottlieb system 80 power on "thunk", all play field lights come on, a couple seconds later all score displays come on and alternate back and forth from 000000 to last high score. It's at this point the ball gate cycles open then closed over and over(main play field) , while this is happening the lower play field relay cycles on and off over and over again. The start button does nothing, so im unable to play a game.
Ive check all fuses, and checked all contacts in case something was stuck in the closed position. I've also checked all connections and re-seated just in case. At this point im not sure where to look next.
Does any have any idea what could be wrong or suggestion of what else to check?
Any help would be greatly appreciated.
#2 1 year ago
Do you have credits in it? All three balls loaded into the trough?
Everything you've described sounds correct
#3 1 year ago
Quoted from zacaj:
Yes, balls in place and credits.... When the game is turned on and boots, immediately the ball gate and lower play field relay cycle on and off non stop.... (would cycle for ever if i didn't turn game off)
This is normal?
I ask because im not familiar with this game and how it behaves. Seems to me the non stop cycling isn't right when the game over is light up
#4 1 year ago
Quoted from itsab67:
This is normal?
That's part of the attract mode. Not sure why the gate cycles, but that's how they coded it.
Does the start button work in switch test? How about the trough switches?
#5 1 year ago
Quoted from zacaj:
I will check on that and come back to give you the answer
#6 1 year ago
Before i try this, could you explain how to do switch test, i assume i press the little red button inside the coin door?.... Then what?
#7 1 year ago
Check your manual, page 13. Basically, hit the red button until you're on #18.
#8 1 year ago
Quoted from zacaj:
Ok, i did the switch test and two numbers were shown 04 and 14.
Before i did the switch test i manually entered credits by moving the little wire that a coin would fall on and after doing this the game started when i pressed start (i was told the game had been modded for free play). Solenoids appear dead so the game can't be played, but they work in solenoid test
#9 1 year ago
Machine doesn't recognize 3 balls in the trough.
#10 1 year ago
Quoted from vdojaq:
There are 2 switches in the trough, One switch should be covered by two balls and the second switch covered by one ball correct?
#11 1 year ago
When you run the switch test, the only numbers you should be seeing (once the drops have been reset) is 25 (third ball in trough). 15 is the outhole, make sure that's working so that it can kick balls into the trough.
#12 1 year ago
A little update
I did a switch test with all drop targets reset and the balls in trough as shown in photo, and the test read back swith 04.
Some more observations that might help pinpoint the trouble...
when i press the start button, the game plays its "music" and the left solenoid in the photo tries to move the ball but doesn't seem to have to power to do so, the solenoid on the right in the photo never moves at any time. Everything on the playfeild is dead, roll over switches etc
#13 1 year ago
4 is the C drop target, check that the switch is adjusted correctly. If you help the game pop the third ball into the trough, will the right coil then release a ball? Does the left outhole kicker move freely if you turn it by hand? It won't release a ball into the shooter lane until all three are in the trough. Do any of the coils work in coil test? If they're all weak/non-working, could be a power board or connector issue. If it's just the outhole then check its fuse
#14 1 year ago
If you help the game pop the third ball into the trough, will the right coil then release a ball? I tried doing this and no, the right coil dosent release the ball when i try this.
Does the left outhole kicker move freely if you turn it by hand? YES, it moves freely by hand.
Do any of the coils work in coil test? .yes they work in self test, the left one is weak and the right dosent move, everything else works and appears strong.
#15 1 year ago
All fuses are good
#16 1 year ago
All fuses are good
The right one is controlled by an external transistor mounted under the playfield. It's one of the ones that normally gives that 'thunk' on startup. Take a read through http://pinwiki.com/wiki/index.php?title=Gottlieb_System_80#Remote_Mounted_Transistors.
For the left one, lift the playfield a bit and try grounding the lug attached to the non-banded side of the diode, see if it fires strong or not. If it's strong then, you've got a connector or board issue. If it's still weak, probably a coil issue
#17 1 year ago
Clean and check all board connectors.
#20 1 year ago
OK thanks, ill have a look at that and do some testing and report back.
I DIDN'T mention that the right solenoid thunks on power up but nothing after that, i should have mentioned that, don't know if that changes your theory.
#21 1 year ago
If it thunks then, that says the external transistor at least is probably fine. Check continuity from the base of that transistor back to the lamp transistor that controls it
#22 1 year ago
Quoted from zacaj:
.So im hoping when I trace the line from right solenoid back to connector / board ill find the problem for the right solenoid. What i don't understand is, the right solenoid not working causes you not to have a ball in the launch lane.... But the rest of the playfield should work after pressing the start button, correct ? Meaning if I touch a roll over switch or target or bumper with my finger they should all work right? Well not only dose the ball not get delivered, nothing works on the playfield..... Is fixing the right solenoid going to bring everything back to life here?
<blockquote cite=
#23 1 year ago
It might not energize till it sees there's not a ball in position three? Can't say for sure. If you fix that drop target switch, maybe you can verify that the 3rd ball switch is really registering in switch test. The rest of the playfield could be a completely different issue, or could be causing this issue.
#24 1 year ago
Quoted from zacaj:
ok, made some progress, the reason why the left solenoid is weak and the right not working is because as soon as the start button is pressed the game tilts. i didn't notice this before but after reseating the sound board connection the game now says "Tilt, Tilt, tilt..." and the tilt light comes on the face of the game. this explains why the playfield is dead, i never noticed this before because there was not audible clue, and I didn't think to check for tilt light with door open. anyway, i have inspected the tilt switches and visually everything seems to be ok, so im not sure why its tilting right off the bat. The tilt ball has been removed, the tilt plumb is all the way down and miles away from the ring, and the slam switches are closed. what else could make the game think its tilted.?
i have inspected all connectors and reseated each.
#25 1 year ago
Another update
well, for the heck of it, i reseated comnectors again.... and yes! it works! soooo happy. everything seems to work ok except one pop bumper is dead. but other than that its good.
Want to thank everyone for all their time and help. Thank you so much!
#26 1 year ago
I hate to thread jack this, but I have a similar problem with my Black Hole. Here's what happens:
1) Pin powers up, waits five seconds, enters attract mode (ball gate clicking, score flashes from 0 to 300,000). Display 4 does not display.
2a) Pushing the the "credit" button causes the game to "hang" and cycle a solenoid on the lower playfield repeatedly. Nothing else works (flippers etc). Game must be restarted.
2b) Pushing the self/test button does nothing as best as I can tell.
#27 1 year ago
Quoted from Inside:
i also had display 4 not working, with the power off i reseated its connector a few times and it worked. in fact all the issues i had turned out to be poorly seated connectors, in the end i probably reseated them all at least 5 - 7 times each. now every thing works good except one pop bumper
$ 50.00
1,800 (Firm)
West Greenwich, RI
2,550
Fort Wayne, IN
$ 1,099.00
€ 8.40
$ 5,799.00
Great American Pinball
Yorktown Parts and Equip
Metal-Mods
