Ok read all black hole /fuse blowing stories still doesn't help.So when you push right flipper fuse 13/upper playfield front bumber blows .With the fuse out I get full continuity haven't checked yet for voltage reading at fuse .stuck at work and thinking about fixing black hole .as you can see in the picture bye the right flipper there is a loose wire where would that wire go?
