Repair log for recently obtained Black Hole.
Because who would not want two of the most iconic solid state Gottlieb sitting side by side? Haunted House is going to have a roomate.
Work list as of 11/10/19
Flipper power relay repaired (contacts all mangled)
A2 power board replaced (brought main displays back online)
Cleaned all board contacts.
Transistors on chaser board replaced (lights out)
1 major, 1 minor transistors replaced on driver board (malfunctions)
Ball release for shooter lane repaired (frozen)
LPF ball kicker coil replaced (still non-functional, working on circuit)
Reflowed pop bumper boards, need to update one
Replaced EOS switch inner right flipper
Rebuilt inner left flipper
Cleaned and reinstalled plastics (going to replace)
All Comet LED, some lamp sockets repaired.
To do list:
Clean upper right rollover switch (erratic)
Replaced elastics, plastics and lane guides
Replace disc motor
Replace window gaskets and finish polishing.
Replace under playfield remote transistor for upkicker and add pull up resistors.
Ground mods, slam switch mod and remove battery off MPU
Finish buffing out playfield and minor touchup
New coil for upper captive hole (weak, wrong part number)
Update last popper board.
New power supply caps.
Impression: Well I have not been able to play in the lower playfield yet but my impression is better than what I have gathered in the past playing this title at shows. Its fast-fast-fast which is what I like in a game. The few examples I have played before seemed slow and ponderous. Glad I had not written this one off as one I was keeping an eye out for.. but it was close.
Led usage:
Backglass now has Comet retro in warm white, the playfield inserts are retro natural white except for the green and blue inserts which have green or blue LED. The main playfield GI has clear dome retro warm white bulbs while the lower playfield has 5 LED white towers for GI illumination. Poppers all have 2SMD LED natural white.
My aim is to always look somewhat stock with just the slightest pop.
