Took a look at a Black Hole today, what do you think a decent deal is for a player's machine BH described below:
Pros:
-Inserts mostly flat
-Drop targets are ok
-Game does start up and play
-All displays appear to work
-Sounds and speech works
-Seller said boards were looked over by professional but didn't look at them myself
-Seller recently replaced rubbers
Cons:
-Some plastics cracked, I would want to buy a new set
-There was some black electrical tape covering about an inch square on the lower playfield, feels like there is a hole under it. I didn't peel it off since it wasn't my game and seller didn't know what was under it. Maybe large spot worn to wood?
-Also there was about a 2-3inch (what appears to be) a crack under mylar in the middle of the lower playfield (mylar was lifting along it)
-Bubbling under mylar (mostly under inserts), both playfields still mylar'd from factory. Would want to remove all mylar, assuming that would be risky.
-Paint worn under mylar for pop bumpers
-Dirty playfield and posts
-Flippers need to be rebuilt and most likely pop bumpers too
-Assuming connectors need to be re-pinned and need to do ground mods
-Cracking of translucent blue on backglass for player 1 display, rest of blackglass ok
-Motor for spinning disc doesn't work
-When I put game into diagnostics, during coil test, main fuse blew, seller said that doesn't happen when game is played. So may or may not be a problem. Seller said boards were looked at.
-Paint on cab head planking/cracking. Also saw a piece of bird poop on back of head. Main body cabinet paint is a little better but large spot of wear to wood on one side.
In my opinion, this game is in player's condition and needs a total shop out. I made a cash offer when I was there in person but he didn't take it. So in your opinion, what's a decent offer for this machine in that condition? I've been wanting this game for quite some time but price needs to be right if I need to put $300-400 into it and plus a ton of time.
