Quoted from dsmit165:Pretty new to fixing pinball machines, I just purchased a black hole and in order for the pop bumbers to trigger the ball has to slam into them very hard, and sometimes they lock on for 3sec, anyone have any ideas to why this is happening or what I should do/check any help is appreciated.
Check your switch gap and making sure your pop driver boards have been updated. Clean those switches too by pinching a business card between them and sliding the card. The abrasiveness of the business card will safely clean the contact points. Do not sand or file them!
As far as them sticking is concerned, I'd almost guarantee that residual magnetism is the culprit.
When I ran into this with my BH, I tried just about everything to correct the problem.
The fix is actually very easy.
Your coil stops are magnetized.
Contact PBR (pinball resource) and buy new coil mounting brackets (which have the coil stops riveted on.)
Once you replace these you will find that your pops no longer "stick"
I tried to drill out the old stops and just replace them (reusing the old bracket) but that didn't solve it.
I also tried to "demagnetize" them without any success.
The new coil brackets are relatively inexpensive. All four on my upper playfield were sticking. Since I replaced them a couple of years ago, the problem has not returned.
