Quoted from Quench:
Is it possible there's been some high voltage spike (possibly the 30 volt rail??)
That is entirely possible, the game was in really bad shape when I got it. I replaced the small transformer, all the bridge rectifiers, put in a fuse for the small transformer, new caps, new mpu/power supply/driver board combo... and on and on. The wiring was a mess but I straightened it all out and it looks good. It also plays great now, no issues at all with game play. I just finished cleaning it all up with new rubbers, worked out all the solenoids and switch issues etc, and it looks amazingly better than it did. It needs new plastics for sure, but these are livable and don't hinder gameplay. I also made a new wireform for the roll under on the lower playfield to advance the multiplier. It was missing and that just wouldn't do! I used a small welding rod of some sort (can't remember exactly what size but need to get more from the welding suppliers). I got a piece of it a while back and have made a few since then, it works great! They didn't even charge me for it because it's nothing to them lol. I had no idea what the original wireform looked like, but I figured out how it had to be. Pictures attached as well.
Things left to do on it are #1 sound of course.
2. back glass spinner motor. I've read all the threads on it and will probably get to it one day... it's not really #2 on the list lol.
3. Auxiliary lamp driver board needs a new chip, one visibly fried but can get it from Vancouver cheap. Will add it to DAC order.
4. Small credit display also has a visibly fried chip and doesn't work. I tried putting a spare display in that I had laying around, and it worked but after a while it blows the fuse for all the displays on the new mpu. Those fuses are hard to find and I ended up getting a couple from Pascal Janin directly from France. Oddly enough, I get shipments from him in just a few days. Anyhow, I'm fairly certain that the credit display is to blame for blowing the fuse, even though it seems to work fine for a while. I haven't blown a fuse yet when I keep it unplugged.
I'll post some pics of the clean up work, and how it looks now, as well as a few overall pics of the sound board. There isn't much to see as on the surface it all looks pristine, but maybe something will catch your eye. I put new capacitors on, that's about it.
Quoted from Quench:
The LM741 op-amps at U21 and U22 are also connected to the +/- 12 volt rails. Your original UA741C op-amps were rated to +/- 18 volts DC max. Since you've changed the op-amps and it's made no difference, it's possible the originals were ok.
I actually only changed U22, not U21 although I do have a new LM741 for U21. I didn't want to change it if I didn't have to, just more chance of harming the board. If you think I should change it just let me know and I'll swap it in.
Quoted from Quench:
I wonder if your R13 pot is bad. With the machine off, set your multi-meter to resistance mode. What resistance do you measure across pins 2 and 6 of U22? This is where the R13 pot is connected across. The schematic says it's 10k ohms so you should read this or less depending where the pot swipe is adjusted to. Do the same across pins 2 and 6 of the op-amp at U21
It seems to be working. I get 1.67k ohms at pins 2+6 U22, and 3.27k ohms on U21. I have R13 backed out to get the sound louder, which is why it's lower ohms of course. I tried adjusting R13 in and the resistance went up accordingly.
Quoted from Quench:
The DAC0808 version is still available at Mouser, Digikey and Jameco. Is shipping any cheaper from these suppliers for you?
No, it would be the same or more actually. I don't mind paying $20 shipping for a $2 part really, but only if there is some chance it will help. I guess I will order them anyhow so we can at least cross them off the list. You said if they're damaged then U14 is damaged as well. Would that just mean there would be no speech? Or would all sound be affected?
IMG_4186 (resized).JPGIMG_4194 (resized).JPGIMG_4197 (resized).JPGIMG_4219 (resized).JPGIMG_4220 (resized).JPGIMG_4238 (resized).JPGIMG_4239 (resized).JPGIMG_4240 (resized).JPG
