Hello pinsiders!! So last night my wife and I are enjoying a few adult beverages playing my new black hole and she starts acting up (the game that is)! When I hit the start button the ball wouldn’t load into the shooter lane and the displays would go blank right after I hear a click under the playfield. I checked all the switches and found nothing. So today I finally bring myself to upgrade the power supply, finish ground mods, update pop bumper boards and do the pull up resistor mod. Hoping to slove my problem. So I pull the power supply board out, pull the heat sink, replace r10,r3, cr7,with parts from gerbers upgrade kit, I also grounded c1 cap to the heat sink and ran a jumper on the back side of the board from ground to the heat sink mounting screw! I put her all back together and plug in the j1 conn and turn it on and Snap the f 2 fuse pops! I had the same issue a week ago but instead of replacing components I just grounded the c1 neg side cap but when I unhooked the c1
Cap ground the fuse wouldn’t blow and the game would work fine. So I unhooked all the ground mods I did this morn and now I’m not getting 5 volts at tp4 it’s at 1.9vdc. So I tried adjusting the trim pot to get 5 volts and I’m getting no voltage change. I can’t figure out why when I hook up c1 to heat sink for ground and do the jumper on The back of the board it pops fuse f2? I assume my pot is bad and that’s why I’m not getting my 5 v adjustment. This is my first gottlieb and I understand they are different than my bally and Williams games. I guess I’m glad that I enjoy working on them as much if not more than playing them but I definitely want to make this thing bullet proof and don’t want to worry about if it’s gonna work or not for the day. Any help would be appreciated!!!!
