I hooked up and powered on my Black Hole restoration for the first time today. The game was not working when I got it, prior owner said it would go into attract mode but would not start a game. I did not verify that before I took it apart (rookie mistake I know). It has a Rottendog 80 MPU and a replacement power supply board as well.
When I powered it on for the first time I got a knock from the coils (which I understand is normal) but also a flash from all the GI (which I don’t think is normal). The MPU appeared to be booting up and I got zeros on the displays. After a few seconds the displays would flash 700,000 then back to zero. It did not go into attract mode. MPU had 5 volt LED lit solid and the reset LED was flashing when I glanced at it.
I turned it off because I thought (maybe just anxiety) that I smelled a burning smell. I did not see any evidence of damage to the boards and did not hear any coils drop out when I turned it off.
F4 fuse blew on the first power up, I replaced it with a new fuse and it blew again on power up (this time the coils pulsed but no GI flash). With F4 fuse holder empty Gi lights up fine, rottendog MPU has reset LED solidly lit, 5V LED 1 is lit, displays show zeroes and then show 700,000 every 5 seconds. Game will not go into self test mode. I don’t think it’s in attract mode but I’ve never seen attract mode in this game, I don’t see insert lights flashing around the playfield though.
Ok, so from what I’ve read the 38 volt rectifier might be bad, I could have a locked on coil (although I didn’t see one locked up and I didn’t hear a coil drop out when I powered down) or I could have a short at a solenoid. I checked all my solenoids visually and I didn’t see an obvious wiring issue.
Questions:
How do I go about testing the 38 volt rectifier?
Is it possible I fried the MPU? That initial GI flash has me a little concerned. Not sure why it’s not going into test mode at all?
Thanks in advance.
