(Topic ID: 199511)
Black hole boots but...
By Cherga
6 years ago
  • 17 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by frunch
#1 6 years ago
This machine has been riddled with issues since I acquired it about a month ago. I’ve slowly chipped away at shoddy, half-baked repairs and am close to having a working machine but not quite there yet. The machine powers on and initializes the displays after 5 seconds as it should however none of the relays engage. When pressing the start button, the game starts without sound and all solenoids/relays are dead. The playfield displays are all lit as they should be at the start of a game. Power supply is a new Rottendog, all four bridge rectifiers have been replaced, fuses are all good and correct values, MPU is a brand new Swemmer and the driver board is a known good spare I had (swapping with the original, produces the same symptoms).
Any help on suggested next steps is appreciated! Thanks
#2 6 years ago
The under pf relays may have been jostled and are not actuating correctly. With power off you can ensure that with light pressure the relays have free movement. I think those are also tested in lamp test 16 as well.
#3 6 years ago
Does coil test work? Is the interconnect cable known good?
#4 6 years ago
Everything moves freely. Coil test does not work.
#5 6 years ago
Starting with the easy stuff, is there power at the coil lugs?
DMM set to DCV, red probe on a coil lug, black probe on game ground.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
#6 6 years ago
Interconnect cable is known good also
#7 6 years ago
No power on any coil lugs
#8 6 years ago
Quoted from Cherga:
Fuses good? There should at least be power at the controlled coils
#9 6 years ago
Yes, all fuses are good, checked and checked again
#10 6 years ago
Solenoid fuse holder was loose. Relays and solenoids firing now but still no sound aside from the occasional explosion sound which randomly activates. Game starts and plays but randomly resets (displays shut off and game is unresponsive) on drain. Sometimes on the first drain and sometimes on the second.
#11 6 years ago
Ok, I found a burnt wire going to one of the coils and replaced it. Reset issue appears to be resolved but still no sound...
#12 6 years ago
Quoted from Cherga:
Does the sound test button do anything?
#13 6 years ago
This machine is one thing after the other... got the sound going, found loose wire on the harness between the driver board and sound board. Now I have the upkicker from the lower playfield getting locked on upon power up. I read somewhere there was a mod that required the use of a pop bumper board to drive the upkicker instead of the logic driving it from the driver board. I can’t seem to find a procedure for this mod. Can someone point me in the right direction or give me some ideas on how to fix the issue otherwise? Thanks
#14 6 years ago
Quoted from Cherga:
If it's locked on, one of the transistors is bad. I'm not sure about the pop bumper mod but cliffy sells a bracket to add an EOS switch to protect the coil
#15 6 years ago
Looks like Q15 on the driver board is the culprit. I’ll order a replacement and report back. Thanks
#16 6 years ago
Replaced Q15 and the upkicker is no longer getting locked but is extremely weak and doesn’t kick the ball up the tube. I installed a new playfield transistor but that made no difference either. Coil is good and just to test, I replaced it and have the same result. Tube alignment also seems ok as the upkicker fires and isn’t obstructed. Not sure where to go next with this...
During all of the work I’ve done on this machine I noticed the pull up resistor mod was never done so I ordered the 4.7k’s along with new 2N5880’s to at least get that completed.
#17 6 years ago
Here's the link to Cliffy's page, his contact info should be there. http://www.passionforpinball.com/
Email him about the Black Hole up-kicker mod. It's a bracket w/an EOS switch. You'll also have to replace the coil with a flipper coil (A-20095). When i got my game the up-kicker coil was actually too strong, causing the ball to hop from the outlane to the inlane at least 50% of the time it got sent up from the lower pf. So, I ordered up the bracket and coil. took several tries to get the strength just right (by adjusting the EOS switch), but it's been great ever since. Definitely worth a shot, imo.
2,500
Ottawa, ON
$ 1,159.00
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/black-hole-boots-but and we tried optimising it for printing. Some page elements may have been deliberately hidden.
