(Topic ID: 226750)
BK2K Owner: Help Needed, Flashers in Test mode
By ChrisHibler
5 years ago
    #1 5 years ago
    Hopefully a Black Knight 2000 owner can help a brother out.
    With freshly burned as well as older BK2K ROMs, during coil test, the AC relay will fire to enable C side flashers but the main enabling transistor (1C - 8C) never fires. i.e. In test, the C side flashers never fire. This happens with two different known working MPUs.
    Does your game do the same thing?
    Thanks in advance.
    Chris Hibler - CARGPB #31
    http://ChrisHiblerPinball.com/contact/
    #2 5 years ago
    I think I have the answer, thanks to Jim Palson @ JT Amusements.
    Switch 2 is an indicator in the switch matrix that the AC relay is in either the A or C position.
    Whirlwind fires the C side flasher no matter what.
    Black Knight 2000 requires switch 2 to be in the correct state before firing the flasher.
    Switch 2 is an opto-coupler on the interface board.
    http://www.ChrisHiblerPinball.com/Contact
    This page was printed from https://pinside.com/pinball/forum/topic/bk2k-owner-help-needed-flashers-in-test-mode and we tried optimising it for printing. Some page elements may have been deliberately hidden.
