Alright this is an odd one. I'm in the home stretch of getting my BK2K up and running and this is one of the last gremlins.
The problem:
While the game is on and in attract mode, the magnet under the playfield does what I'd describe as "pulse erratically". I can hear a "thud" type of noise every time it's energized and there doesn't appear to be a rhythm or regularity to it. I've placed a ball over it while it's doing this and the magnet kind of limply slings the ball around and sometimes holds onto it. Sometimes it goes away, sometimes it happens for a while. The most current iteration it sounds like a heartbeat. It also seems to sometimes coincide with the GI relay being on or off. Here's a video of the sound which also shows the weird relation to the GI relay:
During a game, hitting the Magna-save switch registers with the game and the correct sounds, lights, and display appear, but the magnet doesn't capture the ball, it works similarly to how it's working during attract mode i.e. limply slinging the ball around, kinda-sorta capturing it.
Things I've done to diagnose/fix:
- On a whim I replaced the TIP 102 at Q14
- Aux board header connectors have been reflowed and cleaned
- Aux board caps have all been replaced
- Aux board fuses have all been checked and verified to be the correct rating and have continuity
- Cleaned and filed the leaf switch contact for the magna-save button
- Verified I have voltage at the High Current Driver under the playfield
- Reflowed solder on the connectors and TIP36C of the High Current Driver
When I pulled the High Current Driver board from the playfield I ran a diode test on the TIP36C (Using this as a guide: https://vetco.net/blog/test-a-transistor-with-a-multimeter/2017-05-04-12-25-37-07) and got some results that seem to indicate this transistor could be dead. I wasn't sure if the diode and resistor on this board could interfere with that test and potentially give me bad results.
My current suspicions are either the TIP36C being dead or a short to ground. The intermittency of it is making it hard to diagnose. I guess my question is, would a dead or failing TIP36C exhibit these symptoms or am I barking up the wrong tree? Could the magnet itself be flaky? I haven't run an ohm test on that. What reading should I expect from a "good" magnet? I've attached some pictures of the High Current Driver (these are from before reflowing connectors). I can also add updated board pictures if needed but some out of date ones can be viewed in this thread: https://pinside.com/pinball/forum/topic/black-knight-2000-won-t-boot#post-5810248 ( The U21 and U22 sound roms have already been swapped to the correct socket )
