I've discovered that the magnasave coil is no longer energizing. The voltage on both wires at the connector going in to coil are 6v. I've checked the fuses and looked at some of the past threads, but in those threads there was no power to the coil. I've done the basic checks on Q14 (without removing it) and these tests seem good. I've found the setup board on the underside of the playfield and it passes the 6v as mentioned above. I could really the help of someone who is familiar with this problem. I've been at it for a few weeks and am at wits end. I can't seem to determine if the circuit uses a relay. Also, how does the firing mechanism work? If there is already 6v at the coil, then does firing the circuit cause the voltage to jump? If so, what voltage should it be jumping to? Please forgive the basic questions as I am doing the best to learn how to help myself.
