Restored a machine for a customer and it worked fantastic.
Shipped it to him. He called me after set up saying that it keeps dying and that he never played a game.
Here is what happens the machine powers up into attract mode but doesnt cycle the wall motor before doing so and the test report flashes test motor. Everything in attract mode works as it should lights sounds etc.
Upon depressing the start button the machine begins to start a game as normal for about 3 seconds then locks up. Display is dark, No controlled lighting, no sound. To get out of the lock up the machine must be powered down.
If during attract mode the coindoor test buttons are tried sometimes Test mode can be reached but then it cannot be exited. Again only sometimes You can get into test mode.
Basically the coin door buttons dont function.
The machine is not in a slam tilt mode
At one point it was noticed that the Magna save button switch blades were making contact. Must have been done during shipping. The switch gap was corrected and the game came up normally, the motor worked as it should and two balls were just shot around.
During the working game mode he tried to use the coin door buttons to see if they were now functioning and they still did not. He powered down the game to get out of test mode and the game was back to the same lock up sequence.
Depressing SW2 on the CPU does not change anything with the board diagnostic LED
Upon power up the 5v LEd comes on quickly followed by the Led on the far right. The diagnostic center Led comes up right after in the fast blinking mode.
No board corrosion I reflowed all of the pins on all boards, New fuses all voltages read as perfect.
The game played spectacularly before it was packed and shipped.
Any ideas?
