I'm on a multi year journey restoring my Big Time and I've gotten stuck. I'm having an issue that appeared to come out of nowhere with game start either not lifting a ball or sometimes lifting a ball but then not closing the shutter when first ball is shot.
I suspected something might be going on with the ball trough switches. All tested good except the ball 8 switch which is supposed to be closed when a ball is resting on it and open when no ball is on it. The switch always tested as closed even when it is physically wide open. I thought maybe I had a short in the switch or wires from the switch. I finally traced up to the jones plug into the head that this switch is attached to. I pulled the jones plug and the switch is now measuring as open when its open and closed when it is closed. I next tested the circuit from the female end of the jones plug to see if there might be a short somewhere further upstream, but everything tests fine when the jones plug is disconnected.
Looking at the schematic I think there is a parallel circuit passing through the timer that might be the reason the switch always tests closed which makes no sense at all.
Do I have some kind of short somewhere in the circuit or am I just chasing a dead end?
Any help is appreciated!
Allen
