Upon reset for new game score motor just keeps spinning
I KNOW THAT IS NOT MUCH TO GO ON but that’s all I have
At least it’s a challenge lol
Any help would be appreciated
Thank you I will try that
I just manually reset the bar with player 1 and 2 relays (there are others) turned machine off and it seems to be ok now
It will probably happen again and the I can check the switches with paper
I am very new to this I am assuming these switches are on the alphabetic relay and have those colored wires coming out of them correct?
Yes, if you still have the paper labels on the relays, that will identify each relay. Each of the switches on the schematic snippet are labeled with the letter of the relay that they are on. So you use the wire colors to identify which switch is the one shown on the schematic. Tracking down the right switch is half the fun....
The switch labeled "MOTOR 1C" is on the score motor.
Those are the switches that make the score motor run. If any of them are shorted or closed when they shouldn't be, the motor will run continuously. Hopefully, blocking them with paper will help you figure out if one of them is your problem. Then you have to figure out why that switch is staying closed (or shorted) when it shouldn't be. A schematic will be necessary for that - do you have one?
Here is one good write up on the symbols and how things work related to the schematic.
https://pinside.com/pinball/forum/topic/em-pinball-circuits-basics-to-not-so-basic
This page was printed from https://pinside.com/pinball/forum/topic/big-shot-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
