Quoted from MarkG:Do you have the schematic? There's a normally closed switch at Motor 1C (8H on the schematic, red+white wire to white wire) that connects the power rail to all kinds of 10 and 100 point things. If that's not closed all kinds of things won't score.
/Mark
Thanks for the reply, Mark. I suspected that switch, I think on the manual it is the fifth switch, and checked it. Also, the reason I don't think that is it is because things further up the circuit, such as the B, I and G rollovers and the in lane and outline rollovers, do work.
For further info, the outlanes score properly lit or unlit. However, the inlanes, which run through the B and G relays, will score 500 when lit but not 100 when not.
I have gone over all those make/breaks on the B,I and G relays and they are all good. Even when the m/b are in the 100 position, they will not score. Same is true for the bullseye targets. Score at 500, not at 100.
