Hello,
I had a closed EOS switch on one of the left flipper coils and it melted the coil. This fried the corresponding transistor on the SDU, I believe. I've replaced the EOS and the coil but the neither of the left flippers work. The right one's work fine. I took the SDU out of another 1980 Stern game "Cheetah" and put it into "Big Game"...both the flippers worked. I then put "Big Games" SDU in "Cheetah" and the left flippers didn't work. So, I am pretty sure its the transistor.
I went to my manual to see if they can tell me which Transistor corresponds to the left flipper coil. I don't see anything. I've narrowed it down to Q1 to Q19. The transistors that are currently on the board are SE9302...It seems you replace these with TIP 102.
I put the game in test mode because the manuel says that the coils fire in their order and that the order corresponds with their number on the SDU. I am having difficlty doing so
I am new to testing transistors, and not very confident at doing so. I have a good meter, just never got good at using it. I've read that you test the current transistor (SE9302) different than the one i replace it with (TIP102), something with a diode.
I am, however, good at soldering and dont mind doing that to the boards.
Ok, my questoin...does anyone know which transistor it is, which Q # am i replacing? I'm considering replacing all 19 but figured i'd ask the community first. Ya'll always help!
Dan
