I recently purchased a Big Game pinball (early Stern) as a parts machine to fix my Cheetah. When I got it home, I reseeded the rectifier board turned it on and the game started right up! It started a game and almost all switches and lights worked, I couldnt' believe it.
I then decided to remove the battery and put a battery pack on the MPU. went to radio shack and bought the same battery pack and diode 2n4001 that's on my Cheetah and installed it the same way. Went to turn on the game, and now it wont. It runs through the boot up and makes all the 7 chimes, but when I hit the start a game button, nothing. It has credits loaded. A ball is in the kickout hole, although I don't think this is necessary on old Sterns'.
When I run the diagnostic tests, all solinoids fire and almost all lights light up. it just won't start the game, and I can add credits.
once again, it worked fine for about 4-5 days. Worked just great until I added the battery pack. I have since removed the battery pack and still same issue.
one more thing, I noticed that the MPU has a little bit of solder from the negative terminal on the board where the (-) side of the battery connects when I added the battery pack. When I look at the traces on the board, it looks like this shouldn't be a problem but its the only thing that has changed so I wanted to mention it. I included a pic.
Thanks for any help!
