Temporarily joining the club... Fixing this one up and will probably pass it along to a friend:
Have party this weekend and needed to get ge Z card working quick (X and Y are pretty reliable), so I busted out my soldering iron:
Had a lot of interesting problems, but it pretty much works now...
Two questions though:
1. If I cradle a ball on the lower flipper and then release the flipper to make a shot, the ball gets trapped in a little nook between the upper flipper, the end of the lower flipper and the metal guide, which sits lower than the lower flipper. Is that normal, or are my guides mounted wrong?
2. I tried to put the backglass in, but it's very hard to do because the lower 7 digit displays stick out past the slot for the glass. The holders are mounted on the inside of the insert like they should be, but the glass is still basically touching the displays?
