Yes indeed. I have worked on literally hundreds of crane machines.
There is a version of this board that has 4 chase circuits and a version that has 3 chase circuits.
Yours appears to be the 4 circuit version (the number of TRIACS on the heatsink).
The transformer drops 110v to possibly 12 volts. There is a zener diode to drop that voltage to near +5 volts dc for the ICs to use.
Anyways the circuitry for the chasing is 5 volts. (The ttl chips you see.)
There is a pot in front of the transformer for the chase speed adjust.
The fuses are for each output circuit. In this case the board has 4 chase outputs of 110 volts AC.
The chips generate a chase pattern that controls the TRIACs mounted to the aluminum heat sinks.
The 110 AC in goes from the connector pins to the transformer.
The outputs from the fuses go to the connector pins then to the AC HOT of each of your chase light strings.
The 110 AC common is visible if you turn the board over and look at the traces at the connector pins. There are two that are joined together.
You mentioned 60 volt bulbs..If your crane has 60 volt bulbs, they are wired in series in pairs to create a 120 circuit.
You failed to mention if anything was wrong with this board but I am assuming you havent had it hooked up.
The biggest failure is the electrolytic caps go bad from the heat of the board being mounted on the cranes ceiling. Heat from the light fixtures and all.
Resolder the transformer terminals and then replace all the caps for a 99% guaranteed repair.
I would test it first before investing in the caps to see if it is functional at all.
Ok to hook it up. Starting where you have the two white wires.
That is the 110v AC in. Put the HOT on the left.
So it is HOT 110 AC, then NEUTRAL 110 AC, then Common NEUTRAL 110 AC to all of your light strings, then the HOT #1, HOT #2, HOT #3 & HOT #4 (individually switched on and off by the TRIACs) go to each string of lights.
Hope this helps.
