(Topic ID: 215514)
Big Buck Hunter Optos Stuck Closed
By zucot
6 years ago
#1 6 years ago
I'm troubleshooting a big buck hunter where the Bird and Ram opto switches are stuck closed in test.
I have replaced the optos.
I have replaced the opto amplifier board.
All of the other switches in that row work fine.
I have not tested the other switches in the Ram or Bird opto column.
As soon as I plug in the 5 pin connector on the opto amplifier board, the switches are stuck closed in test.
As soon as I plug in the switch drive connector at J1 in the backbox, the switches are stuck closed in test.
The opto switches are not glowing red at any point.
Is it likely a transistor for those switches? Anyone know which transistor it is? The BBH manual is not the best.
Any help would be appreciated!
#2 6 years ago
Quoted from zucot:
no it would not be a transisitor.a transisitor is for the coils and flashlamps not optos it sounds like a problem on the opto board.i would also say its not the connectors because you said the optos close when you plug in both connectors on cpu and opto board.the optos not glowing clearly indicates a problem on opto board or the wiring go to and from the opto board.there should be a small red led light on the opto board.is it blinking or staying lit?
#3 6 years ago
Thanks for the reply. The lights on the opto amplifier board flash and go dead as soon as I plug the 5 pin wiring harness in. This happens with and without the optos plugged into the board.
I reseated all of the wires in that 5 pin connector.
This opto amplifier board came from a known working game.
#4 6 years ago
are all those optos in the same row in the switch matrix chart?
#5 5 years ago
Quoted from Cycloneman:
Yes.
#6 5 years ago
check and see if theres continuty with a meter from the connector to the board.there might be a break in the wiring
$ 76.00
Lighting - Backbox
Arcade Upkeep
$ 29.99
PR Mods
$ 40.00
Game Room Info Shop
$ 55.00
Gov's Mods
arcade-cabinets.com
$ 54.99
$ 29.95
Professor Pinball
$ 24.50
$ 14.95
South Berwick, ME
Game Room Info Shop
This page was printed from https://pinside.com/pinball/forum/topic/big-buck-hunter-optos-stuck-closed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
