(Topic ID: 225209)
Big Buck Hunter buck movement
By RalphT3
2 years ago
  • 20 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by RalphT3
#1 2 years ago
I have a Big Buck Pinball and for some reason, the buck that moves across the playfield will not "stop on a dime" anymore. She will coast to a stop and will move past its limit switches and jam against the wood locking her into a position which will catch the balls. All switches are clean and registering, even the rotary ones on the motor.
What is making her to not stop properly?
Thanks erverybody!
#2 2 years ago
If the switches are all good, the only thing I can think of is something is out of adjustment so the mech isn't actually hitting the switches....
#3 2 years ago
The switches register in the switch test mode. It doesn't stop on the shell, it will just coast another couple inches and just jam itself past the left most and right most switches and torques itself into the wood and get stuck there. I also have installed a new driver board (unrelated problem) so that isn't it.
#4 2 years ago
What about the optos and encoder disc that determines the bucks location. I remember having a similar issue, and can't remember if I just replaced the disc or opto.
#5 2 years ago
Link to the encoder disc:
https://www.marcospecialties.com/pinball-parts/535-0308-00
Opto should be a fairly common part to find.
#6 2 years ago
Yes, the opto/encoder disc registers in the switch test menu.
#7 2 years ago
When you test the switch, do any other switches register that shouldn’t?
#8 2 years ago
Quoted from jalpert:
No.
#9 2 years ago
And nothing showing in tech alerts?
#10 2 years ago
Quoted from blowback1976:
Nope, none at all. I have the buck almost all the way to the right with her motor DISCONNECTED and no alerts (on both boards!).
#11 2 years ago
Would there be any chance the little ceramic disc or the "light" connected to the 2 motor wires be bad???
#12 2 years ago
+FIXED+
It was one of the 2 large relay boxes underneath the playfield. It seemed like the contacts might be a little corroded (can't really tell, they are sealed) and not letting the normally closed connections let the 20V(?) through making the buck stop completely.
#13 2 years ago
Seems the last couple I have seen on location had this problem. Was this a location game as well?
#14 2 years ago
Quoted from gameover1173:
Yes, It is/was on location at the FEC I work at. Just sold it as it was the last pinball machine in our company. Right now it is in my dock awaiting pickup from the delivery company heading I think to New York. I have put in soo much work into it since I got it in '12 from when our Davenport location closed up. Kind of glad to see it go.
#15 2 years ago
I actually just bought one in st louis. Wounder if it's the same one. It was at the st louis incredible pizza company
#16 2 years ago
Yes it is!!!
#17 2 years ago
Thanks for the extra protection
Much appreciated
#18 2 years ago
Much appreciated
It is how I would want to receive it. Many extra parts included packed up in bubble wrap on playfield for you!
#19 2 years ago
Awesome thank you
Do you know when they are coming to get it
#20 2 years ago
Picked up just before 3:00 CST Thursday.
$ 29.95
$ 12.50
Gweem's Mods
$ 50.00
$ 14.95
Professor Pinball
PinWoofer
Game Room Info Shop
