Expired ad
This ad has expired and was removed from the MarketPlace. The owner has been requested to end their ad, so it can be archived.
This topic is linked to a classified ad.
The Ad Listing has expired, so this topic closed automatically.
Quoted from MinusWorlds:Wish you were closer. Anyone know where to get replacement monitors for these by chance?
Yup, betson should have them. Pricey but it is a hard size tube to find
betson if they have em its like $700. the tubes in these are horrible and always go bad. color gun issues. to bad cant use lcd in games like this. someone needs figure out how to make them work with lcd.
try your local operators. many of the newer (ish) golden tee, silver strike, etc machines had the same monitor and operators are just sitting on these cabinets. i usually buy the entire machine for pennies on the dollar because they are not being used anymore. it also helps that i usually buy 50-75 of the machines at a time so it helps the ops to clear out space in the warehouse.
do you need the entire tube or just the chassis? if it is just chassis repair, there are plenty of good techs that work on chassis.
Quoted from KingPinGames:try your local operators. many of the newer (ish) golden tee, silver strike, etc machines had the same monitor and operators are just sitting on these cabinets. i usually buy the entire machine for pennies on the dollar because they are not being used anymore. it also helps that i usually buy 50-75 of the machines at a time so it helps the ops to clear out space in the warehouse.
The local repair person said the monitor. However, it is in a remote area so I dunno how much they actually know. The vertical something or other is off. The screen powers on but it's basically like condensed into a vertical 1/4" sliver of screen. If that makes sense.
Quoted from joe2012:Vertical collapse. Send the chassis out for repair.
Awesome, thank you!!!!
I agree.
Bump for a good price.
This page was printed from https://pinside.com/pinball/forum/topic/big-buck-hunter-arcade-game-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
