(Topic ID: 144924)
BF DMD Failure
By Sabre68
  • 28 posts
  • 9 Pinsiders participating
  • Latest reply 3 years ago by Crash
#1 3 years ago
Hello,
My kids were playing BF over the weekend and out of nowhere the DMD just went blank. The machine plays fine, just no display.
I'm really hoping this is something simple... any suggestions on where to start?
Thank you
#2 3 years ago
My Baywatch display went blank on me, and I found that Stern/Sega actually had a service bulletin to fix the issue with an updated harness. I can't say for sure it will fix yours but it worked for me. My Batman Forever already had this installed when I bought it.
http://www.marcospecialties.com/pinball-parts/500-6326-00
http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/sb/sb106.pdf
#3 3 years ago
Try a simple reseat of the cables as well - unplug them them put them back on.
#4 3 years ago
Thank you both! I read the service bulletin and I guess it is common so I went ahead and placed the order for the updated harness.
I will, Dendoc, reseat the cables this evening and hopefully that will work and I can get my kiddos off my back about fixing their favorite machine! )
#5 3 years ago
Okay I went home for lunch and reseated all the cables. I didn't see anything visibly wrong with the connections. Turned the power on and the game booted up, but still no DMD. I really hope that updated harness solves the problem. Anyone have any other ideas?
#6 3 years ago
#7 3 years ago
I ordered it from Marco Specialties. The Link is listed above in FlipperMagician's post. It is scheduled to come in today via FedEx. It cost $12 plus shipping. Hopefully I get a chance to install this evening or tomorrow and I will let you know the results...
#8 3 years ago
I finally received my updated harness(Turkey Day slowed things down) and went to install it and apparently there was already an updated harness there. I could tell because the stops on the connector on the power board were already cut out like the instructions asked me to do. It looks like the negative black wire wasn't seated all the way down so I pushed it all the way down in and hooked everything back up. Turned it on and again nothing. Game fires right up and is ready to play but no DMD. Is it possible that the newer harness plugs went bad too? I couldn't see any visual damage and the pins look clean. Any suggestions at this point? Thanks and please remember this is a new hobby for me and I really have no experience with troubleshooting...
#9 3 years ago
Well, it could be a power supply problem - that's a good place to start, checking the DMD panel is getting power.
#10 3 years ago
Okay, I put the MM on the Display and it is getting exactly 5.0 volts. Any suggestions on where to go from here?
#11 3 years ago
Still looking for help with this problem. The display is getting the power it needs. Does anyone have any suggestions where to troubleshoot next? Thanks
#12 3 years ago
BUMP
Still looking for advice.
#13 3 years ago
The common failure that causes this seems to be the HV supply on the DMD board itself failing. That's what I'd check first.
#14 3 years ago
Do you have another big screen Sega pin to cross examine with?
#15 3 years ago
I do not have another DMD to cross examine with. Wish I did. If it ends up being a dead DMD, then does anyone know where to get a new one? Are color ones available? My kiddos really miss this machine, I only own three.
Quoted from falco:
I will check this ASAP
#16 3 years ago
Wait. You've gotten this far and haven't tested for HV power?
Please do that. This procedure is for WPC games, but is identical for your BF.
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Testing_DMD_Controller_Power
If you find the voltages incorrect, LMK. I have a PS that can help you.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact
#17 3 years ago
It's not identical, or remotely the same. These big screen Sega games generate their own high voltage within the display itself. The display receives 12v, 5v, and two grounds from the game via the 4 pin power connector. Power the game on with the display fully connected and check for these two voltages at the display's header pins that connect to the board. Also check for 5v at the display driver board that piggybacks on top of the display itself. If this board is not turning on, it will cause nothing to appear on the screen. Unfortunately there is no way to be absolutely sure the driver board is or is not the problem, but there's a good chance the panel itself has failed.
#18 3 years ago
Quoted from Crash:
Ohhhh. OK....thanks for the info Crash.
Ya know, I'd like to own a Baywatch (there, I said it), but the big screen and i the eventual need to replace it have always stopped me from pulling the trigger.
http://chrishiblerpinball.com/contact/
#19 3 years ago
Have you considered SmartDMD? You can build a kit for half the price as a new DMD.
#20 3 years ago
Quoted from Crash:
I checked these at the header pins and got 5v and 21v. The one on top, piggy backing, also showed 5v. 4.99 to be exact.
So I checked the connector and still had the same results. 5v and 21v.
Crash, if it only is supposed to be getting 12v, then how could it possibly be getting 21?
Also I switched the small ribbon cable and started it up and we actually has some (random) lights on the DMD for a little bit...then they disappeared and we couldn't get anything to show up again, repeatedly switching the small ribbon cable(as someone had suggested earlier)
And Crash, if my DMD is dead, then I would love to build another but I have very little electronic skills being that I've only been into this crazy hobby for less than a year...
#21 3 years ago
You must have a Vishay display, as these use 24v instead of 12v. Every brand has a different voltage for this input. Can you verify yours is a Dale/Vishay? Your 24v supply is too low. Do you see a 24v test point on your power supply board (the board in the upper left of the backbox)?
#22 3 years ago
Quoted from Sabre68:
Well, that's unfortunate. Presumably there's a problem with the PSU. 21V could well do damage. That would be the first thing to fix. Perhaps the panel will come up OK with the right supply voltages, but it's fairly likely that 21V has killed it. It is possible to repair these, fortunately, and given their value, probably worth it.
Alternatively, get a SmartDMD...! A bit of messing about, but should be worth it.
(Edit - didn't know that some displays require 24V. That would explain it, but worth checking that this really as it should be.)
1 month later
#23 3 years ago
Okay, someone suggested replacing the ribbon cable that goes from the top board to the bottom board on the DMD. It's a short 14 pin connector. I purchased a new one and put it on. The DMD now shows life but all you see is jumbled and gargled lights. Before it was completely blank. Does anyone know what this means and where to go from here? I really do appreciate all the help to this point but I'm getting ready to throw in the towel on this machine.(or seek a professional who can come to my house and properly fix the problem)
BTW, The header pin on the bottom board looks like it has been replaced before...I guess you guys refer to as a "hack"?
Thanks again
#24 3 years ago
Where do you live?
At this point, you may want to hire a professional to fix it.
#25 3 years ago
I live in Clarksburg, West Virginia. If anyone knows of a traveling repairman(if that exists) I would be glad to hear about him. I have two pins and a video game out of service at the moment.
Does anyone know where I can get that header pin located on the bottom board of the DMD?
#26 3 years ago
It's most likely a bad dmd. Went through all of the same issues with a frankenstein. Dmd extender for a few colors runs about 230$ the install etc is pretty easy and i was quite a newb back then
#27 3 years ago
Where do I get this DMD extender? I had heard the guy doesn't make them anymore...
#28 3 years ago
https://pinside.com/pinball/forum/topic/diy-addams-family-poor-mans-color-dmd
First of all thanks for your continued support for the DMD Extender, I
really appreciate it.
The only issue with my personal life is getting time to do things with the
DMD Extender - I have a full time job, a family, and other projects on the
go! It's hard to fit it all in. However, my wife is now helping with the
administration and emails so I'm getting a lot more time to do the
manufacture and testing of the kits that are getting ordered. I'm
continually overwhelmed by the popularity of this thing.
$ 224.99
3,400
Havertown, PA
3,200
Romeoville, IL
$ 48.00
$ 399.95
€ 339.00
Displays
GermanGamingSupplies.com
