Can't decide between the Hakko fx 888d soldering iron or the Panavise 324 to help me hold the board and I can only afford one. I have a cheap Radio shack iron now. Not sure which way I should go. I need both.
A good iron will go a lot further if your iron is very basic. I love my panavise, but if it were that choice, soldering iron first.
The 324 wouldn't be my choice in panavises, either.
Wife already gave me the ok to get both but I'm afraid she'll suddenly be asking me for the okay for a new purse...
What Panavise do you recommend? I don't think I can justify spending more money but if the 324 isn't very good maybe I'll just get the soldering iron.
Sorry, I meant to post that info, but got distracted by work and children last night
305 - Base
308 - 5# base weight
315 - PCB vise. Comes with 12 inch bar, holds PCBs up to 10 inches long
318-22 - 22 inch extension bar, allows to hold up to 20 inch long PCB
One tip - look for used parts if you can. These are pretty indestructible. Make offers on people's eBay listings and look for listings with free shipping. If you have to pay separate shipping on 3-4 items, you will probably end up spending as much as buying them new and shipping from a single supplier!
Thanks for the info John. Is the 324 no good because it's too small to hold the larger circuit boards or just kind of cheap?
Quoted from johnwartjr:Sorry, I meant to post that info, but got distracted by work and children last night
305 - Base
I was struggling with a board rocking all over the pace last night, I didn't know these existed. I just checked Amazon and these 4 items are right around $100 shipped with Prime. Can anyone else comment on these over doing board work on a flat surface?
I have a Panavise and it is a great addition and very nice, but a good solder/desoldering station should be your first acquisition. You can mess things up with a cheap iron, most likely you won't damage something if you don't have a Panavise.
I find that I mainly use the Panavise when trying to remove stubborn components where I have to heat both sides of the component to get all the solder to flow and get sucked out of the through hole. The vise is really nice as it frees your hands to get the work done. But for most of my rework, I have the board on the bench and don't use the vise.
Get a good soldering station, and hold out for the Panavise. If you can wait a while, the panavise 324 was around $40 from Radio Shack for Black Friday.
I work on boards daily for hours on end. No vice here, i physically hold the board vertical when desoldering and lay it flat when soldering.
That being said, spring for the good soldering iron first.
Quoted from Miknan:Thanks for the info John. Is the 324 no good because it's too small to hold the larger circuit boards or just kind of cheap?
Well, here's my theory on the 324.. I'm sure there are people who use the 324 and like the 324. I don't mean to imply it's no good or it's junk, because I'm sure it's better than nothing, and quite useful on boards of a certain size. It says it holds boards up to 12 inches wide. So, get a ruler out and see how many of the boards you might work on are 12 inches or narrower. The solder holder is an OK touch, the iron holder I don't see me ever using.
The cross bar could be changed out with a 318-22 so larger boards would fit, if you like. Truthfully, you don't need to buy the 318-22 if you can find a piece of square stock at a home improvement store, welding supply, etc of the right size. You could cut it to length, file the edges smooth, drill a hole, and make your own cross bar of any length you desire.
I prefer the 5# weighted base because when you put bigger boards in the vise, it can tip over if you don't have a weighted base. It just makes a more sturdy arrangement. You could clamp or bolt the base down, but I don't have enough workbench that I can dedicate a certain spot to board repair day in and day out. Sometimes, I have a board on the bench and a logic probe out. Sometimes, I solder and desolder. Sometimes, I'm sorting parts. So, with the weighted base, it picks up and sits on a shelf above the bench when I'm not using it.
I've done plenty of work on boards without a vise. It certainly helps, but is not a requirement. As has been said over and over here, decent iron first. Board vise later, if at all, based on your tastes.
Andrew, as much work as you do on boards, I believe if you tried a vise, you'd like it, and want to have one
Quoted from barakandl:I work on boards daily for hours on end. No vice here, i physically hold the board vertical when desoldering and lay it flat when soldering.
I've gotta go with barakandl on this one. I have a panavise in the closet that hasn't been pulled out in years.
Thanks John and everyone else for your input. I'm going to get the Hakko fx 88d. I had bought that Panavise 324 off Amazon late last night but cancelled it this morning. I'll piece those parts together later when I get some extra money. I'll buy that soldering iron now. Thanks again.
This page was printed from https://pinside.com/pinball/forum/topic/better-soldering-iron-or-panavise-324 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
