Is everyone using rubbing alc. to remove flux residue after soldering? I used to use qtips dipped in alcohol but they get fibers stuck on the work quite often. Switched to a toothbrush - but it tends to splatter and you still need a way to clean up the working surface after.
Anyone have tips/suggestions? I'm resoldeting a new harness at the moment to everything on the bottom of a pf and don't want to splatter the new pf bottom with bits of residue...
