(Topic ID: 158338)
Best way to prevent spills on/in machines
By bstyles
  • 20 posts
  • 17 Pinsiders participating
  • Latest reply 4 years ago by markmon
    #1 4 years ago
    I know can't be the only pinball collector that has nightmares about opening up my clubhouse and pinball collection for events (charity fundraisers, car shows, birthday parties, corporate events, etc.) only to have a non-pinball person dump a drink on the glass and have it drain down into the cabinet.
    That would be bad enough, and you can bet that if it's not seen by my staff, it would go unreported -- only to make matters worse when it was finally discovered.
    So here is what I have done:
    - Attached a PinGulp to the right side of every machine.
    - Added 0.5" tall black text on white background P-Touch labels to each machine's lockbars which read:
    "FREE PLAY - PRESS START. Please Do Not Set Drinks on Glass. Use Drink Holder on Right -> -> "
    - Added 1" tall labels "DRINK HOLDER" labels to the fronts of the Pingulps. (don't laugh, the black plastic pin gulps are somewhat hard to see nestled between the machines which are all ~9" apart from one another in your typical banks.
    Then I have staff members that work the events, which among other responsibilities, monitor the machines for the dreaded drink (bottle, cup, etc.) set on the glass -- the accident waiting to happen. They've been instructed to walk up, remove the drink and hit the culprit with a cattle prod (though they usually just ask them politely). The larger the event crowd, the more staffers I have work it.
    This is a problem that has plagued pinball machines since the beginning, so what measures and precautions do you take to protect your machines while trying to share and promote the hobby with others?
    Has anyone developed a new state-of-the-art replacement lockbar with forward-facing optical sensors that would set-off a siren if a the sensors detect an obstruction, such as a bottle or cup was placed in front of it?
    Has anyone developed a light-up drink holder that maybe draws more attention that a solid monotone plastic PinGulp?
    Has anyone developed an automatic cattle-prod that pops out of the coin door area and teaches the offender a lesson?
    Let's hear what works for you. Thanks in advance.
    #2 4 years ago
    Quoted from bstyles:
    Yes, but it just encourages Beelzeboob to turn with his butt against the coin door and pour drinks over his shoulder.
    Your choices are to not allow food and beverages, have the people playing monitored or putting a convenient drink holder in place and trying to let people know it is there is what most have done.
    #3 4 years ago
    Unfortunately it would be impossible to host an event without food or beverages...
    Maybe I could get custom printed plastic cups that have the "Club 66" logo and the following inscription:
    "If you set this cup is found atop a pinball machine, a billy club will soon be found atop your head."
    #4 4 years ago
    None of my friends ever set a drink down unless its empty.
    #5 4 years ago
    Quoted from Skypilot:
    I'm not worried about my friends or other pinball collectors.
    #6 4 years ago
    Just caulk all the edges of the glass and lockdown bar. Problem solved!
    #7 4 years ago
    You could just continually walk around talking aboot how you will electrically shock, or bash them over the head if they do it. Probably work.
    #8 4 years ago
    Quoted from TheLaw:
    Smack on the neck with thin part fishing pole
    #9 4 years ago
    Only serve drinks in cups with lids and straws also.
    #10 4 years ago
    Quoted from markmon:
    I'm not sure that a beer cup or wine glass with a straw would fly..
    #11 4 years ago
    Sippy Cups.
    In all seriousness, I worry about that as well. I only invite people over that I know and usually communicate my concerns. I've there is people I don't know well(friend of a friend) I just don't allow drinks downstairs.
    #12 4 years ago
    Pingulps seem to have mostly solved this issue.
    There's a beer seal on the lockdown bar for a reason...
    #13 4 years ago
    Replace the apron card;
    Do not sit drinks on game
    Keep it simple, don't try to be funny
    #14 4 years ago
    Do they have to sign some kind of waiver to play? I would charge people double (or X amount over and above the normal fee) and then refund it after the event assuming they did not spill a drink on it. Similar to renting a condo and putting down a cleaning/security deposit. If they scoff tell them what the machines cost to replace
    Would be neat if someone came up with a fluid sensor to install under the lockbar, similar to HVAC when you have a leak in the attic.
    #15 4 years ago
    Jello-shots
    faz
    #16 4 years ago
    The beer guard gasket does work well if it is in good shape. I have had some drinks get tipped over, it is a bit of a mess on the pin, but it normally does not get onto anything that is that hard to clean up.
    I have just had to stop worrying about messes and just accept that if I want to have guests enjoy anything I own it will get dirty. Having small children in my home also helps me stop caring about messes.
    #17 4 years ago
    Obnoxious signs everywhere....."do not set food or drinks on pinball machines" put them everywhere...
    #18 4 years ago
    Make sure you put Please or people will do it to spite you. Just check the machines before you go home so it won't soak in all night.
    #19 4 years ago
    No food or drinks on my games period.............problem solved.
    #20 4 years ago
    Quoted from ForceFlow:
    For those drinks I would have some cup that can be sealed. It's not that odd if you have some large arcade. No way I would allow open wine glasses near the games.
    $ 18.99
    $ 5,899.00
    Classic Game Rooms
    $ 34.00
    The MOD Couple
    $ 74.00
    Id Rather Play Pinball
    $ 40.00
    Metalhead Pinball
    $ 5.00
    RGP Models
    $ 59.00
    Full Tilt Pinball LEDs
    $ 36.00
    bB Customs
    Various Novelties
    Pinball Photos
    $ 9.99
    $ 159.99
    $ 40.00
    Arcade Arts
    $ 4.49
    $ 54.99
    Various Other Swag
    $ 7,999.00
    Little Shop Of Games
    $ 9.99
    $ 99.99
