New! Dark mode!
(Topic ID: 136170)
Best way to fix this WW post?
By johnwartjr
5 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by bballfan
#1 5 years ago
I have a White Water on location that has a problematic post. It's pictured. It's the one across from the upper flipper.
I drilled the hole out, and glued in a hardwood dowel, drilled it, and reinstalled the post. Lasted for about a month.
Logically, it seems like a good location for a t-nut and a machine screw, but I have to take so much apart to get the T-nut installed....
The location is an hour away, and I imagine to get the mini PF out and back in is minimally a 2-3 hour job.
Anybody have any bright or better ideas? Or a way to get to the underside of the mini playfield installed to slip the t-nut in? Or even a lock nut with a pair of needle nose pliers or something?
I have some things I want to try, but since it's an hour to the location - I want to take all the right stuff to get it done in 1 trip
#2 5 years ago
Bolt with nylon nut. Flat washer on bottom side. Fastest way I know.
#3 5 years ago
Quoted from Mk1Mod0:
Wondering if the clearance exists to get to the bottom with a locknut - it's pretty tight in this area.
Anybody have experience?
#4 5 years ago
If room, tape nut & washer on open end wrench to reach spot.
#5 5 years ago
I agree with this. I would also use a washer on the topside. Shouldn't sffect play much if at all in that location and it will be stronger than the wood.
#6 5 years ago
Double up on that 2" rubber ring too.
A ball can easily break that lamp.
$ 49.95
Pin Stadium Pinball Mods
Mesa, AZ
$ 19.99
PinballElectronics.com
$ 175.00
Professor Pinball
