Hey all,
Bought a new set of Holograffix MM side blades but no holes for the hinge bolt - grrrr. In your all's opinion best way to cut. What I have come up with is:
1) trace hole from other set and use a circle blade (like the circumference circle tool) to cut or
2) Remove bolt, make a small hole and create 4 slits (top, bottom at sides) to relieve pressure in blade from tearing once bolt goes back in
Thoughts?
Thx. DP
