(Topic ID: 330331)
Best way to clean light sockets
By cmndr-brain
61 days ago
#1 61 days ago
I'm working on a 1979 Flash pinball that's been in a garage for 25+ years. Dust and grim have infiltrated all parts of the game. What do people recommend for polishing up the lights sockets. Sitting for so long almost all the sockets have a white dust on them. The sockets have what seems to be a paper separator between the contacts and at the bottom inside of the socket. I've tried a tumbler before, but that gets a lot of media in between the contacts and inside. How about an ultra-sonic cleaner with just water? Any other suggestions besides just buy new sockets? You can see in the image, especially the middle, the white dust on the socket. I assume it's just the material the socket was made from reacting with moisture.
#2 61 days ago
That is white rust caused by oxidation of the zinc coating. You can clean with vinegar and a magic eraser, or just buy new sockets, as the galvanized coating is compromised.
#3 61 days ago
PBR has socket cleaning sticks for the inside. I put one in a drill to clean them. As long as the inside is clean, you have good electrical contact.
#4 61 days ago
Dremel and a wire brush tip make quick work of cleaning sockets.
#5 61 days ago
Those are trash. Replace them with new ones. Yes vinegar will get the oxidation off and make them look *nice*, but say good bye to any remaining zinc; your then left with raw steel.
However, if you need to clean sockets that are not too bad (or the game is not worth the investment in new sockets) start with a *Light Socket Cleaning Stick* from PBR.
By itself the stick is not much to write home mom about. But combine it with a *drafting electric eraser* and you can do a respectable job of cleaning the working inside parts of the socket damn fast. I'd say about 10 seconds per socket, in situ.
I'm not a fan of *Dremel and a wire brush tip*...the wire brushes don't last long especially on full blast, and they tend to fling the broken wires all over $%@#'s creation. Yes, eye protection has to be worn, but damn, if you forget and catch one in the eye.
#6 61 days ago
Best way to clean them is to replace them. I recommend yoppsicles.
#7 61 days ago
Quoted from nsduprr:
One of my customers gave me a box of stuff 10 years ago to throw out whatever I couldn’t use, inside the box was one of these drafting erasers. I looked it up and discovered that these things go for about $150 on eBay. I discovered on my own that this is the perfect tool for cleaning light sockets with a PBR stick. Thought I was the only one.
#8 61 days ago
Unless the particular lamp socket is completely unobtainable for some reason (in this case, I'm pretty sure they're readily available), I just replace them when they start getting gnarly. The same problem is only going to resurface later.
Quoted from chuckwurt:
Since that isn't a socket, you lose the ability to choose your bulbs with that solution.
#9 61 days ago
Socket cleaning is never worth the effort, replace them and be done with it forever.
John
#10 60 days ago
Replacing them is a lot of work but once you do so you can forget about it. Otherwise the lights will be intermittent until well after you pass on....
#11 60 days ago
Quoted from rstrunks:
I've only replaced all the lamp sockets on a playfield just once. It was an early solid state game, and it didn't really take too long.
Most other times, it's just been one, two, or a small handful that were faulty or in poor condition.
#12 60 days ago
It seems as though, only the lamp sockets with the long mounting bracket are the ones effected with the corrosion. The short mounts or the ones stapled to the playfield don't seem to have a problem. I'll look into order some. Looks like I'll need to do about 45 of them.
#13 60 days ago
Yoppsicles won't work on williams feature lamps as they require a diode.
$ 9.95
$ 27.95
Other
Men
$ 14.00
Tools
Pincoder Store
Tools
$ 11.00
KAHR.US Circuits
Playfields
Troxel Repair
Playfields
$ 52.99
Pinball Shark
Shooter rods
1,550
Rockville, MD
This page was printed from https://pinside.com/pinball/forum/topic/best-way-to-clean-light-sockets and we tried optimising it for printing. Some page elements may have been deliberately hidden.
