(Topic ID: 161694)
Best Soldering Tip for PCB work
By Russell
2 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by barakandl
    #1 2 years ago
    I have a Hakko 936 soldering station with a 907 soldering iron. What is the best type of tip to use for PCB work? Anyone got a good source/site for buying these?
    #2 2 years ago
    I much prefer a chisel tip over pointy ones for thermal reasons. I think people overall use too small of tips. Solder only wants to stick the copper / solder pads, so pinpoint accuracy is not as needed as you think.
    Irons seem to come with pointy ones too. I would get two different sizes of chisel and see what you like. Some people even like the angled chisel, i like the ones that kinda look like a flat heat screw driver.
    #3 2 years ago
    I agree on the chisel tip, the conical ones are worthless.
    I typically use chisel tips in the following sizes: .0625", .125" and .187". The smallest tip is for IC's (it won't bridge the gap between leads) and small transistors. The next tip is for larger (driver) transistors and the last is for bridge rectifiers and under-playfield work.
    #4 2 years ago
    Thanks, everyone. Anyone have favorite source for buying this sort of stuff?
    #5 2 years ago
    Quoted from terryb:
    I find with my hakko that i need to nearly lay it on its side to solder with it. I thought that is how you were supposed to use the conical tips that way. I must say I prefer the chisel tip of my old weller but not gotten around to replacing the tip on the hakko.
    #6 2 years ago
    i get my hakko tips from http://www.bdent.com/
    #7 2 years ago
    Quoted from Syco54645:
    Correct. With a conical tip you have to be almost parallel to the board in order to maximize the contact area. That's a difficult angle to be working at while trying not to burn other components. Bottom line you'll get much more contact area, with less effort, out of a chisel tip.
    $ 76.95
    $ 17.00
    Yorktown Parts and Equip
    Pinball Pro
    $ 49.99
    $ 24.95
    $ 24.99
    Lee's Parts
    $ 90.00
    Geeteoh Electronics
    $ 22.00
    $ 5,799.00
    Gulf Coast Pinball, LLC
    $ 29.95
    $ 48.00
    $ 430.00
    MI Pinball Refinery
    $ 17.00
    $ 60.00
    Mods for your pinballs
    $ 69.99
    $ 40.00
    Metal-Mods
    $ 149.00
    $ 159.00
    $ 7.50
    Bright Lights Pinball
    $ 19.95
    $ 159.00
    Pinball Pimp
    $ 999.00
    Medisinyl Mods
