(Topic ID: 287592)
Best place to order replacement Stern coil stops
By Marty_Graw77
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 3 years ago by timarnold
    Topic poll
    “Best place to order replacement Stern coil stops”
    • Marco 0 votes
    • Pinball Life 12 votes
      86%
    • Other 2 votes
      14%
    (14 votes)
    #1 3 years ago
    Looking at doing the 1,000 play Stern coil stop replacement (why can’t they fix this?! ). For those that have tried the different vendors, who has the best replacement coil stops and why do you think so? Marco and Pinball Life being the two most obvious and similarly priced. Thanks in advance for your input.
    #2 3 years ago
    Never had to. Re-replace a pinball life stern stop. They seem pretty good.
    #3 3 years ago
    I've had to do on 4 sterns. Always keep a few on hand now
    #4 3 years ago
    How hard is it to replace these? Are all modern stern games the same replacement?
    #5 3 years ago
    Quoted from Ty-Arnold:
    Remove (2) 5/16" hex screws, remove stop, install new stop, reinstall hex screws. Total time per flipper is less than 5 minutes. Yes all modern Stern flippers use the same stop. Probably the same since Sega and DE days.
    #6 3 years ago
    2.50 in parts (for both) and 5 minutes of work for every 1000 plays seems reasonable.
    #7 3 years ago
    Pinballife of course
    #8 3 years ago
    Quoted from TheLaw:
    Stern should just quit fighting it and start buying all their production parts from Pinball Life. It's way overdue.
    #9 3 years ago
    Quoted from Hayfarmer:
    Which brand/vendor?
    #10 3 years ago
    Be aware that there are 2 different coil stops for Stern-Sega-Data East.
    The most common has a small hole. The older type used only on very early Data East TYFASSI flippers has a bigger hole. The centers are the same.
    You can stock just the smaller hole type and then make the hole larger with a drill press when you run into the need for the larger version. Or, you can stock both.
    This page was printed from https://pinside.com/pinball/forum/topic/best-place-to-order-replacement-stern-coil-stops and we tried optimising it for printing. Some page elements may have been deliberately hidden.
