(Topic ID: 210993)
Best Lube for Spinners
By Pmaino
1 year ago
  • 39 posts
  • 29 Pinsiders participating
  • Latest reply 13 days ago by Dayhuff
    #1 1 year ago
    Looking to buy some lube to get my spinners ripping. Can anyone make some recommendations on the proper lube to get?
    Here is what I was looking at:
    https://www.homedepot.com/p/Super-Lube-7ml-Precision-Oiler-Oil-with-Syncolon-PTFE-Lubricant-Per-Each-51010/202932717
    Thanks in advance.
    #2 1 year ago
    I use silicone spray, put some in a paper plate and use a q-tip to apply to the spinner.
    #3 1 year ago
    I use this:
    ebay.com link
    Looks very similar to the HD stuff you linked. The applicator works well.
    #4 1 year ago
    Super Lube
    amazon.com link »
    Take fine grit (300) sand paper to smooth out the tips of the spinner, then take a Q-tip to apply a very very small amount. You should not be able to see any lube. Viola! Juicy spinners!
    #5 1 year ago
    That will work BUT I found Zoom Oiler to be best. Plus great for many other things. I got mine at local hardware store.
    amazon.com link »
    IT JUST TAKES A VERY TINY TINY DROP on the spinner.
    #6 1 year ago
    there is a custom made lube or spinners here in the cleveland area. 2 words. Salas-Juice. The locals here will know
    #7 1 year ago
    Quoted from Pmaino:
    Thanks in advance.
    Honestly, I would try the super lube you found!
    The gel form works great on other pinball items, but would be a bit too viscous for a spinner. The low resistance carrier for the Teflon in that version seems to work great for me on other delicate projects.
    I think that the little oiler tip on that smaller bottle will work well for your application.
    Obviously, regardless of what you use, make sure your spinner wires are clean/smooth/straight/etc as well.
    Certainly let us know how it worked out!
    #8 1 year ago
    Thanks everyone for the quick responses.
    #9 1 year ago
    I use the Zoom Spout Oiler
    #10 1 year ago
    Astroglide or KY usually for a tight "spinner"
    #11 1 year ago
    I use 3-in-1 oil with the telescoping spout. One drop per side, clean up any excess (no visible oil volume when done).
    #12 1 year ago
    Quoted from vdojaq:
    Of course we all know vdojaq was talking about one of these to keep him occupied
    #13 1 year ago
    Anyone polish the spinner axles first then lube?
    #14 1 year ago
    I use Kellube. Mainly because of the awesome precision applicator but also because it's locally made a good stuff.
    #15 1 year ago
    Quoted from Gundam_Pilot_:
    +1 on the Salas Juice tip.
    #16 1 year ago
    Tri-Flow squeeze bottle for me. I think Were all using/saying about the same thing. Use a petroleum based PTFE added low viscosity oil. I have been using Tri-Flow for years on the same spinners and there is no build up etc- so I can say it works and is clean. I am sure all the other stuff works well too!
    #17 1 year ago
    Quoted from turbo20lbs:
    Quoted from FatPanda:
    Super Lube
    amazon.com link »
    #18 1 year ago
    im a big fan of this stuff. http://a.co/eeDyFsR
    couple of drops on a Q-Tip and lightly touch both ends of the spinner and give it a spin.
    #19 1 year ago
    Quoted from rufessor:
    I've used that tri-flow on other non pinball stuff and thought it was pretty good. I noticed if you use too much (like too big a drip and just leave it) it can leave a little (small amount) white residue. I'm wondering if it has a higher Teflon content or something (may be a good thing?).
    I don't have my super lube products in front of me, but off hand, I was thinking those may be a silicone (not petroleum) base. Can't recall off hand...either way, just an observation. Both probably work very well in small quantity that would be needed.
    I liked that OP had a link to super lube at a box store. I know harbor freight and ace hardware carry super lube products but unsure if they have the little tip one like that.
    Is tri-flow sold in stores as well? I can't recall where I got mine, but thinking I ordered it.
    #20 1 year ago
    One application and you’ll never have to touch your spinner again.
    #21 1 year ago
    Great product! (if I don't say so myself)
    #22 1 year ago
    I use treadmill silicone lube.
    But I'm curious what everyone else uses.
    #23 1 year ago
    Glad I saw this thread - I didn’t know this was a necessary thing for spinners! Perfect timing as I’m working on one right now..
    #24 1 year ago
    I have used superlube for over 20 years, think I am only on my second tube. (I have bigger toothpaste size tube). That's the stuff to use. Once applied it doesn't break down as fast as thinner naturals so it lasts forever.
    #25 1 year ago
    Quoted from Rdoyle1978:
    Personally, I don't feel it's "necessary" and I almost never do unless it is staying a bit sluggish/sticky no mater what else I do, but some people want the extra spin etc.
    #26 1 year ago
    I just use a small bit of Wax to lube spinners (and shooter rods).
    #27 1 year ago
    Quoted from pacmanretro:
    Seems like it would be more fun if the spinner goes nuts. The one on my MB was so gunked up the ball wouldnbrick on it almost every time. New decal, new lube! I wonder if it would reflect light from a spotlight well?
    #28 1 year ago
    I hear you. And, and I agree, certainly ripping that spinner is fun!
    I typically have seen more reasons why it doesnt free spin due to exactly that; being gunked up, etc. Straight, unworn, cleaned well, etc seem to do pretty well and if you want super action above that a drop of lubricant probably doesnt hurt. But if it isn't spinning pretty free to start, there are other issues that oozing more oil over won't cure (in general I mean, not your MB per say).
    I actually always wondered if the lubricant would just wind up attracting more dirt and grime, but it is such a tiny amount, it probably isn't all that significant.
    #29 1 year ago
    In my experience, I've never had to re-lube a spinner after the first time (using regular old 3-in-1 oil).
    I don't think the longevity argument is a factor. Even if I had to do it once every 5 years, I'm cleaning the game anyway by then I hope.
    3 weeks later
    #30 1 year ago
    Quoted from stevevt:
    I use this:
    ebay.com link
    thanks for the link I am in need of something like this for my roadkings.
    blake
    #31 1 year ago
    I used 3n1 silicone on my spinners 2 weeks ago. What a difference!
    #32 1 year ago
    Quoted from djreddog:
    HFS, that's awesome
    Guess I need to break down and lube mine.
    1 year later
    #33 14 days ago
    Funny, I was the last post in this topic and now posting again... I had been using 3n1 (with no complaints), but just ordered me a super lube precision oiler, going to give it a go, curious to see if I notice a difference.
    #34 13 days ago
    where are you actually putting the oil/lube?
    #35 13 days ago
    #36 13 days ago
    I use Franks Red Hot.
    #37 13 days ago
    I just use olive oil
    #38 13 days ago
    Quoted from Bud:
    I put that shit on everything. Lol!
    #39 13 days ago
    I never use lube myself. (no pun intended). Just make sure there clean and lined up properly and balanced....
    That's all you need to do.
    John
    Professor Pinball
    $ 75.00
    Great American Pinball
    $ 40.00
    Bright Lights Pinball
    $ 29.00
    $ 69.99
    $ 19.95
    $ 32.00
    Pin Monk
    $ 99.99
    $ 0.35
    $ 27.99
    $ 36.99
    Lee's Parts
    $ 248.00
    $ 209.99
    $ 48.00
    $ 17.50
    Playfield - Plastics
    $ 6,995.00
    Flip N Out Pinball
    $ 29.99
    $ 39.99
    $ 7,499.00
    Classic Game Rooms
    $ 27.99
    $ 18.99
