What's the best design to use as a heatsink for a bridge rectifier? Square basket style is the most common. On one of our PSUs the rectifier gets pretty hot and you can smell it if you're working in the backbox. But the game still runs fine.
I would say anything of a reasonable size that you can bolt to the heatsink, with some thermal compound, would help.
Agree! Just... Do Not Forget the thermal compound! http://www.MaximumPC.com has some stats for what ones are the best!
-Aaron
Iowa Pinball Club
For awhile, I was providing the 'pin-fin' BGA type heatsinks on my rectifier boards. These are the short ones with an array of heat dissipating 'spikes'. After giving them a second look - I found that these are optimized for forced air cooling rather than convection. Need heatsinks more optimized for convection rather than forced air for pinball machines. The basket type heatsinks tended to have convection thermal resistance values (about 9.4) much lower than the pin-fin heatsinks (15 or higher) ... the lower the better.
Hard to tell on the extruded heatsinks such as those used by Williams on their WPC boards as there is no thermal resistance value listed. These vary widely depending on construction and size.
Some people use the TO-220 folded type heatsinks such as the 563002 from Aavid. These work but aren't real good... thermal resistance of about 13.
Attached are pictures of the pin-fin, basket and folded type heatsinks.
Thermal compound also makes a difference but not a huge one. Depending on the type of compound - this adds a thermal resistance between 0.8 to 1.2. Good stuff runs about 0.8 whereas the cheapy paste with silicone runs about 1.2 with a myriad of versions between.
Can get Hi-Flow heatsink pads (stick on pads such as Berquist HF115TAAC) - these are about 0.9. Not bad but cost much more for the convenience of not being messy and coming in the form of a sticker. Complete lack of heatsink compound results in a huge thermal resistance rise but actual amount depends on surface roughness.
Now... the real question is how good is good enough.
So many variations, impossible to answer but shoot for a thermal resistance as low as you can go and you should be ok.
To cover a tiny bit about thermal resistance - this tells you how much a part will heat up while dissipating a certain amount of wattage. To get total thermal resistance - add parts junction to case resistance (bridge rectifier = 1.2) plus case to sink resistance (thermal compound roughly = 0.9) plus heatsink-to-ambient resistance (folded heatsink = 9.4) for a total thermal resistance of 11.5.
Multiply this times the wattage dissipated to get temperature rise above ambient temperature (25C). So with two diodes always on within a bridge rectifier with a current of 3 amps x forward voltage drop of 1.1v... bridge typically dissipates about 2x3x1.1= 6.6 watts. 6.6 watts x 11.5 C/watt = 75.9C rise. Add ambient temp. of 25C and you have a temperature of just over 100C... quite hot! We could now go into why Williams went from GBPC type bridges to 6A4's but too much info...
There... clear as mud?
Ed
I have been using these on my Bally/Stern PCBs, are they any good?
http://www.radioshack.com/product/index.jsp?productId=2102857
Dont forget how important room temp is. If your room is 85 degrees, you will not get any cooler than that.
I just make sure I have a controlled temp and everything else will work as it should
This heatsink looks promising:
http://www.gizmodo.com.au/2012/06/use-this-gorgeous-chimney-to-silently-cool-your-superhot-cpu/
Quoted from G-P-E:To cover a tiny bit about thermal resistance - this tells you how much a part will heat up while dissipating a certain amount of wattage. To get total thermal resistance - add parts junction to case resistance (bridge rectifier = 1.2) plus case to sink resistance (thermal compound roughly = 0.9) plus heatsink-to-ambient resistance (folded heatsink = 9.4) for a total thermal resistance of 11.5.
Ed
Damn Ed...once again...you da man!
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://webpages.charter.net/chibler/Pinball.htm
This page was printed from https://pinside.com/pinball/forum/topic/best-heatsink-for-bridge-rectifiers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
