Quoted from Tommi_Gunn:i don't see the point, unless you're desoldering tons of stuff everyday or you're sloppy at it. desoldering guns are more of a pita than anything. unless you need to break out the Big Guns for extensive work. kinda doubt it for the majority of pin work. my 808 is still in the box. i use to think the same thing. i need an 808! life will be so much easier. right.
$3.95 does the trick just fine. in and out.
I've used the soldapult type desoldering tools in the past. They work OK for some jobs.
The quality of my rework has improved 500% since I started using vacuum desoldering stations. I use mine a lot. I can justify the expense personally because of the frequency I use it.
When I remove an IC from a PCB, you could reuse it if you wanted to. I can desolder a 40 pin PIA and have the holes clean and the chip look new in under 2 minutes, without lifting a trace.
I can't say that for when I used desoldering braid and a soldapult. Of course, I've repaired hundreds of boards at this point, versus just a few back then, so some of my proficiency at this point is undoubtedly from the additional experience gained in repairing more boards.
That A1006 tip, btw, is a godsend on relays, trying to remove a relay with a soldapult or braid is kinda like trying to push a rope.
