(Topic ID: 242918)
Bench grinders
By Murphdom
5 days ago
  • 22 posts
  • 10 Pinsiders participating
  • Latest reply 3 days ago by Murphdom
    #1 5 days ago
    This may be a duplicate thread but I couldn’t find it with the search tool. What does everyone use on their bench grinders to remove rust and polish metal with? Is there a specific type of polishing wheel or type of grinding/grit of wheel I should get? I’m due for a trip to Harbor Freight anyway. Thanks in advance.
    #2 5 days ago
    I don't use a bench grinder for rust removal--just buffing with a cotton wheel and grinding with a grinding wheel.
    For rust removal, usually evaporust.
    But if I'm doing something manually, sometimes steel wool. I just picked up some abrasive balls for a drill at harbor freight, so I may give those a try instead.
    If I'm regraining something like a lockbar, I'll use a drill and 3M flap wheels with different grits.
    For polishing, sometimes I'll use the bench grinder, sometimes my drill with with a cotton buff bob, sometimes a variable speed polisher for large surfaces with a cotton or fleece bonnet. For any polishing, I'll use a tube of green compound. When done, I'll wipe the part down with a microfiber towel.
    But, it's an evolving process depending on what the part is, the shape/size of the part, and the amount of rust removal or polishing needed.
    #3 5 days ago
    There's a lot to know about polishing metal, but suffice to say you would use a "sisal buff" with either a black or brown rouge to "cut" (ie smooth) and a cotton buff with a blue or white rouge. My recommendation for the minimal amount of equipment to do the most types of things is a sisal with brown and a cotton with blue. Brown seems generally safe for all metals (whereas black isn't) and blue is a safe finish for both metals and plastics.
    I'm by no means an expert, but I've recently gone through what you're going through. I ended up with the HF 6" buffer with various wheels and rouges. But learned quickly that it doesn't need to be as complicated as many will make it sound for our pinball parts. If you're trying to restore a vintage car to a pure mirror shine, then yeah, but getting some pinball parts sparkling clean isn't all that complicated.
    #5 5 days ago
    A fine, brass wire wheel on one side of the grinder helps at times, too.
    #6 5 days ago
    What about something like side rails?
    #7 5 days ago
    I've used a brass wire brush to get good results to de-rust a coin door quickly. The brass is soft enough that it doesn't scratch the finish underneath.
    #8 5 days ago
    i use buffing wheel on a bench grinder. i like to use a red rouge, same thing they use on jewelry, as a polishing compound its fast easy and they look like new
    you can get the stuff at harbor freight
    #9 5 days ago
    Thanks for all the tips I will have to try them to see what I find works best. So out of sheer convenience today I tried using my 9 year old sons rock tumbler from harbor freight with corn cob media on some metal posts and screws since I am working on a machine that is older and has a ton of metal posts. It worked amazing after only a couple of hours and it gave a mirror finish with just the media by itself. I will try adding a polishing compound later to see if I get an even better result. I would have tried walnut media because I have read that it’s even better but my son is allergic to nuts and I didn’t want to take any chances. Now to the coin door, coin plate, and shooting rod with all your advice. Thanks again
    #10 5 days ago
    If you use a buffing wheel try the green rouge. It’s for stainless steel, but is great on chrome and zinc plated parts, just about all metal on a pin.
    #11 5 days ago
    Quoted from Murphdom:
    Did you turn that thing loose on some feldspar?
    #12 5 days ago
    Quoted from Boat:
    #13 5 days ago
    way too many rocks
    #14 5 days ago
    Isn't red rouge the one you want to stay awsy from?
    #15 5 days ago
    Quoted from chad:
    Yes. Cancer causing.
    #16 4 days ago
    What’s the best way to regrain a coin door? Someone had already previously cleaned the door and the center of it is a little grainy.
    26198572-F2B0-4EEE-95E3-917976B32EAB (resized).jpeg268FB1DB-B632-489F-91C9-DB7BBCD20066 (resized).jpeg89BDE0D5-729D-4811-B98E-036CD0C585D2 (resized).jpegBF5E50C4-D120-4724-B4E5-63CAA53CEDFE (resized).jpeg
    #17 3 days ago
    The 3M Scotch Brite sanding wheels are magic for that
    #18 3 days ago
    Quoted from ktownhero:
    Is that the same thing as the gray and red pads?
    #19 3 days ago
    No. They are flap wheels and can be used in a drill.
    #20 3 days ago
    Quoted from ForceFlow:
    Is there a specific grain or type? There a bunch to choose from
    #22 3 days ago
    Thank you
    $ 38.00
    $ 69.99
    $ 49.95
    pinballmod
    $ 79.95
    $ 6.00
    German-Pinball-Modular
    $ 18.95
    $ 7,199.00
    Classic Game Rooms
    $ 64.99
    Lee's Parts
    $ 14.95
    $ 9.95
    Playfield - Plastics
    € 3.70
    $ 39.95
    $ 7,499.00
    Nitro Pinball Shop
    $ 119.95
    $ 14.95
    $ 234.99
    $ 209.99
    $ 221.00
    Cabinet Parts
    Tilted Pinball
    $ 29.99
    Meph's Mods
    $ 214.99
